Please Help, definition for 97 4g93 Mirage with 00MIRAGE ECU
Postby ComputerGeek11s » Tue Jun 14, 2011 9:02 am
Hello everyone, my name is James and I was wondering if someone could help me with a xml definition file for my ecu. I would like to beable to change my fuel map, timing map, obd table, injector scaling, maf size, filter, and etc. Thankyou some much.
My Mods:
4g93 built block
10:5:1 Wiesco pistons
titanuim rods
billet crank
800cc injectors
GT40R turbo
SPA turbo manifold
2 combined MSD DIS-2 Boxes
Tower stack coil
4g93rom.hex
(128 KiB) Downloaded 714 times
ComputerGeek11s
Re: Please Help, definition for 97 4g93 Mirage with 00MIRAGE
Postby ComputerGeek11s » Thu Jun 16, 2011 3:15 am
I have made a xml for my rom now, but I have a another problem when flashing to the ecu EM2569.
[20:50:02.937] -- comparing ECU flash memory pages to image file --
[20:50:02.937] seg start len ecu CRC32 img CRC32 same?
[20:50:03.078] LB7 00010000 00003000 2A164224 4D8A51C3 NO
[20:50:03.093] SB0 00013000 00000200 6B78F0C0 6B78F0C0 YES
[20:50:03.109] SB1 00013200 00000200 1C844863 1C844863 YES
[20:50:03.125] SB2 00013400 00000200 47EEEDD3 47EEEDD3 YES
[20:50:03.140] SB3 00013600 00000200 E436927C E436927C YES
[20:50:03.156] SB4 00013800 00000200 C95193E8 C95193E8 YES
[20:50:03.171] SB5 00013A00 00000200 F1099BAD F1099BAD YES
[20:50:03.187] SB6 00013C00 00000200 BD7BC39F BD7BC39F YES
[20:50:03.203] SB7 00013E00 00000200 BD7BC39F BD7BC39F YES
[20:50:03.406] LB6 00014000 00004000 8EA36FB1 8EA36FB1 YES
[20:50:03.593] LB5 00018000 00004000 C98F7D85 C98F7D85 YES
[20:50:03.796] LB4 0001C000 00004000 DDFCB279 DDFCB279 YES
[20:50:04.000] LB3 00020000 00004000 8BC138FF 8BC138FF YES
[20:50:04.187] LB2 00024000 00004000 330FB01D 330FB01D YES
[20:50:04.390] LB1 00028000 00004000 23F3F5CA 23F3F5CA YES
[20:50:04.578] LB0 0002C000 00004000 640646E1 640646E1 YES
[20:50:04.578] kernel flash enable
[20:50:04.593] kernel blank flash page: addr: 00010000
[20:50:19.609] WARNING: failed to erase page at 00010000!
[20:50:19.609] kernel flash disable
[20:50:21.625] interface close
ComputerGeek11s
Postby todd-w » Fri Jun 17, 2011 1:59 am
open the case and check the processor see if its h8539fa if it is change the def file
<memmodel>H8539F</memmodel> to <memmodel>H8539FA</memmodel>
todd-w
