Definition needed for 2008 ADM EVO X SST
Postby RS200Z » Tue Dec 07, 2010 12:09 am
Hi there, appreciate if someone can provide the XML for the above mentioned EVO X model.
Attached is the ROM file.
2008 ADM SST.bin
(1 MiB) Downloaded 815 times
RS200Z
Re: Definition needed for 2008 ADM EVO X SST
Postby ptharris » Tue Dec 07, 2010 2:11 pm
here you go
53050006.xml
(13.98 KiB) Downloaded 767 times
ptharris
Postby RS200Z » Tue Dec 07, 2010 6:45 pm
Thanks, it worked! :)
RS200Z
Postby RS200Z » Thu Dec 09, 2010 7:13 pm
Hi, I realized the value for the following 3 tables are all 159.4 which looks weird compared to a 2008 JDM EVO X SST. Can I check if it's due to a problem with the XML addressing the wrong address/table?
- Boost Target Engine Load #1A (High Gear Range)
- Boost Target Engine Load #1B (High Gear Range)
- Boost Target Engine Load #2 (Low Gear Range)
RS200Z
Postby ptharris » Sat Dec 11, 2010 12:27 am
some one has changed that rom, i mapped a std 53050006 yesterday and the rom is fine
See attached
std.bin
(1 MiB) Downloaded 775 times
ptharris
Postby zigzagzok » Sun Dec 26, 2010 1:55 am
hi can anyone help?
despite the definition file below, there are still some tables not defined yet...
much thanks in advance!
open loop load low octane #1 and #2
reactive solenoid wgcd correction interval (high.low gear)
reactive solenoid max total upward wgdc correction
reactive solenoid max total downward wgdc correction
boost control rpm per mph xover
also cant seem to fine open looop vs close loop toggle
53050006.xml
zigzagzok
