Def for 39670016 AU Ralliart Colt
Postby sherpa » Tue Oct 26, 2010 8:09 pm
Hi Guys,
I've been playing around at home for a while with these defs and i've got a few things done but if a more experienced member can go over them that'd be great. just some of the x and y axis are random. other thing that confused me is there's only one majorly apparent throttle map i could find (well 2 but the other one is for when the car goes into semi limp mode) whereas the evox has 4 of the buggers. These rough defs also loosely apply to the European colt czt. Any help or info would be greatly appreciated.
39670016ColtRalliart.bin
(768 KiB) Downloaded 923 times
39670016.xml
(13.64 KiB) Downloaded 874 times
sherpa
Re: Def for 39670016 AU Ralliart Colt
Postby sherpa » Wed Oct 27, 2010 6:38 pm
Played around a bit more last night. There's a few maps i've got as unknown maps that i cant match/recognise. They look very suspicious ha. Wow this stuff is so different compare to the tiny commodore roms i've seen before. In the evox roms when the definitions were being made how the heck did you guys find the target idle rpm's in the rom?
39670016v2.zip
(2.43 KiB) Downloaded 418 times
sherpa
Postby dtctuning » Thu Nov 11, 2010 6:52 am
Hello all,
I tried bootloader and new version sw ecuflash 1.43.3150 on a colt czt from 2005 but no response.
Does the 2006 colt czt have a different ecu or something or is there another reason it did not work?
Maybe I should try the 1.43.3172 version.
Hope that somebody has an answer,
dtctuning
Postby sherpa » Fri Nov 12, 2010 4:52 am
hey mate,
are you using an op2 cable? On the au colts you need to cut wire 11 from the back of the obd port and wire this to the reflash connector on the op2. I'd check the workshop manual to find the exact pin. On the au its pin 136 of the ecu and is labeled 16v flash or something. The m32 needs a 16v signal in order to initialize the reading/writing procedure. And 1.43.3150 can only read whereas 1.43.3172 can write aswell. I will attach a pic of the wire.
sherpa
Postby dtctuning » Fri Nov 12, 2010 5:36 am
Yes, I am using OP2 cable. I used this pinout http://www.evoscan.com/technical-vehicl ... liart-colt for bench flashing. It sounds like you guys read in write in the car?
Also, does the OP2 cable make a 16v output on pin 11?
Thanks for the help!!
dtctuning
Postby clck » Mon Apr 18, 2011 2:40 am
I was working on a JDM 05 version of colt version R 5MT using ecuflash 1.43beta3172
Manage to clear checklites for
big MAF housing
hks sqv (VTA)
asc
etc etc..
Was reading and writing ok until possibly low battery and ecuflash show error in the middle of a flash
On the bench using a set of working harness (works well on cz4a ecu).
double check all connection according to evoscan website. Connect Kline, can+, can- and 16v program pin + power lines
Just couldn't flash using Recovery mode.
Is Recovery mode disabled in beta version?
Write button shows in beta 315x n 3172, but not on beta 3272
Any suggestion?
TIA
clck
Postby Mitsiman » Mon Apr 18, 2011 6:40 pm
The reflash for the colt only works on the australian model ecu's, not the JDM / European colts. You will have bricked the ECU and need to get it reflashed by Mitsubishi
Mitsiman
Postby clck » Mon Apr 18, 2011 11:27 pm
It works on ecu ID33520002
It just hang up on me after about at least 10 flashes.
Question is does ecuflash 1.43b3172 allow bench flash?
clck
Postby Mitsiman » Tue Apr 19, 2011 12:32 am
It should do
Mitsiman
Postby clck » Tue Apr 19, 2011 7:25 pm
Think I bricked the ECU big time
Even Mitsubishi can't fix it, saying bootloader corrupted !?
clck
Postby Mitsiman » Tue Apr 19, 2011 8:55 pm
That sounds correct - I am amazed that it didn't do that the first time you flashed it.
The alternative is the guys from Pisiani can resurrect the ECU or ECUTEK can as well. They are your only choices
Mitsiman
Postby clck » Wed Apr 27, 2011 6:24 pm
Singapore
clck
