4G93 ECUFLASH
4G93 ECUFLASH
Postby betogt » Tue Sep 28, 2010 4:00 pm
HI, I ALSO HAVE A MITSUBISHI MIRAGE LS COUPE 4G93, I JUST OVERHAULED THE ENGINE AND IT HAS A COMPRESSION OF 225 PSI. SO I WANT TO FLASH MY ECU, BUT THIS CAR DOESNT HAS ANY OTHER PORT FOR THE TACTRIX CABLE, SO I HAVE UNDERSTOOD THAT THE TACTRIX PORT HAS TO BE TAKEN FROM THE ECU, BUT I DONT KNOW WHAT PIN OR PINS SHOULD I HAVE TO CONNECT TO IT. IF YOU COULD HELP ME ILL APPRECIATE!!! THANK YOU VERY MUCH FOR YOUR TIME!!!
betogt
Re: 4G93 ECUFLASH
Postby todd-w » Fri Oct 01, 2010 3:19 pm
what year ? metal or plastic ecu case , try a wire to pin 79 at ecu for the white init socket .
todd-w
Re: 4G93 ECUFLASH
Postby betogt » Sat Oct 02, 2010 10:22 am
its a 99 mirage!!! plastic case
betogt
Re: 4G93 ECUFLASH
Postby todd-w » Sun Oct 03, 2010 1:44 pm
put a wire into pin 79 at the ecu and connect to the single wire white connector on tactrix cable
todd-w
Re: 4G93 ECUFLASH
Postby betogt » Thu Oct 07, 2010 4:18 pm
ok thank you very much!!!!
betogt
