knock sensor
knock sensor
Postby betogt » Sat Aug 21, 2010 10:20 pm
hi, yesterday i modified the timing map on my cs lancer 4g18, i gave +20º on the timing at 4000rpm´s+, and i was monitoring with mitsuloger. now, my question is, does this engine has any knock sensor? because i was watching the knock sum column and it always kept on 0, or is there any other program that detects this knocks?? i also tried evoscan, and the same thing, 0 knock sum. can somebody resolve my question? thanks
betogt
Re: knock sensor
Postby todd-w » Sat Aug 28, 2010 2:17 pm
yes it has a knock sensor usually located in the block just below the inlet manifold
todd-w
Re: knock sensor
Postby betogt » Tue Aug 31, 2010 4:57 pm
ok thanks, but why when i run mitsulogger it doesnt gives me any knock at +29º??? is it handling it well or is there any problem?? thanks
betogt
Re: knock sensor
Postby todd-w » Sun Sep 05, 2010 1:50 pm
i would say normal ,you could use a set of det cans to double check, what afr ?
todd-w
Re: knock sensor
Postby hpd_wally » Tue Sep 07, 2010 8:20 pm
I would check your knock limit map as well, to ensure that it is not clamping the applied value, though I think you hope it will.
If your methodology is to add that much timing at a load site, without monitoring afr, egt's or actual torque output, you may be hurting you engine for no real gain.
Parts of the load cycle (WOT), I would not recommend adding that magnitude of timing. Being that knock systems are still not perfect, and you do not have a very high compression engine, knock activity may not even be detected at that amount of loading.
hpd_wally
Re: knock sensor
Postby richardko » Tue Sep 14, 2010 5:50 am
Bro.... Your lancer XML is 95250001 or 91210001? Can I know where u from?
richardko
Re: knock sensor
Postby betogt » Tue Sep 28, 2010 3:54 pm
my definition is the 91210001, should i try the other one??? if i should, can you send it to me?? thanks!!!
betogt
Re: knock sensor
Postby betogt » Tue Sep 28, 2010 3:55 pm
im from Guatemala, Central America
betogt
