Unable to write airtrek ecu
Postby sgevotx » Thu Jul 08, 2010 8:42 am
I've been trying to flash my ecu but couldn't get it to write but was able to pull the map. Need some help on solving this problem.
Here's the trouble message i'm getting, anyone know what the problem is?? Thanks in advance.
[23:38:02.390] Using interface OpenPort 1.3 Mitsubishi TX34SgYj8050f6c94845ed4dd0edab1a468961236c930ff5
[23:38:04.750] sending init sequence 1 (0001)
[23:38:07.984] sending init sequence 1 (0003)
[23:38:09.000] got 0x05 response
[23:38:09.000] sending init sequence 2
[23:38:09.000] got 0x1B response
[23:38:09.000] sending init sequence 3
[23:38:09.390] entering bootloader
[23:38:09.406] sending kernel size (4420)
[23:38:09.421] sending kernel load address (0xFFFF7000)
[23:38:09.437] uploading kernel
[23:38:10.156] verifying kernel checksum response
[23:38:10.156] kernel valid
[23:38:10.375] kernel get version
[23:38:10.375] rkrv: preamble 1 error
[23:38:10.406] reading kernel comm buffer size
[23:38:10.609] reading kernel flash buffer size
[23:38:10.828] interface close
sgevotx
Re: Unable to write airtrek ecu
Postby sgevotx » Sat Jul 10, 2010 4:50 am
No one know how to solve this??? :?:
sgevotx
Postby Mitsiman » Mon Jul 19, 2010 2:52 am
I am getting the same error writing to another model Mitsubishi as well, must be similiar based ECU's
Hopefully someone will be able to let us know whats happening and how to fix it.
Mitsiman
Postby Mitsiman » Thu Jul 22, 2010 1:43 am
I confirmed this - the error is becasue OpenEcu is not configured to be able to write to these ecu's yet, they are not currently supported.
You would need to beg and plead with Colby to get him to update openecu to be able to work wth these.
Mitsiman
Postby FQ-Airtrek » Wed Aug 04, 2010 4:58 pm
For Airtrek Turbo you can only use Ecuflash 1.29 it wont work with the newer version not unless someone here has managed to work on the definition.
FQ-Airtrek
Postby yee » Sun Oct 10, 2010 8:47 am
Post up your roms if you can. Downloaded rom can be save even you don't have the correct definition, try this way:
When pop up Unknown Rom Image, select Use wizard............., then click next, Select Inherited from the definition below, click next, click next at ROM Identifier screen, Fill up whatever info you have at ROM Info screen, click next then save the rom post up here.
Openport 2.0 & ECUFLASH 1.42 - 1.43 can use on Airtrek without any issue.
With your posted Roms, I'll try my best to send you a matched definition.
yee
