hello everybody,i have fitted anecu from an E7 in my E4,i've swapped the necessary wires but i have the o2 sensor overheat light on, is there a way of disabling this other than removing the light in the dash.i'm running the Evo 7 RALLIART 90550001 map if its in the ecu perifery i've pasted it here, many thanks john..
</table>
<table name="ECU Periphery (FAA) Bits">
<table name="Periphery Bit Number">
<data>bit.15</data>
<data>bit.14 (Front 02 Heater Circuit) ???</data>
<data>bit.13</data>
<data>bit.12</data>
<data>Disable EGR / Enabled Ign Adv (set bit=1)</data>
<data>bit.10</data>
<data>Enable Warmup Ign Retard</data>
<data>bit.8</data>
<data>Enable High Oct Ign Map Lookup (and many other subroutines)</data>
<data>"WG solenoid? Enable Speed Limit Test"</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
</rom>
