kill immo on usdm evo X 5speed
Postby napado » Sun Mar 28, 2010 1:13 pm
hello,
I tried to kill immo on usdm evo X, but i saw an error message.
[17:36:01.015] EcuFlash Version 1.42.2595
[17:36:01.015] OS Version Windows XP
[17:36:01.015] Qt Version 4.5.0
[17:36:01.031] 56 memory models read.
[17:36:01.031] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:36:01.437] 590 ROM metadata models scanned.
[17:36:01.437] checksum module "subarudbw" loaded.
[17:36:01.437] checksum module "mitsucan" loaded.
[17:36:01.437] flashing tool "wrx02" loaded.
[17:36:01.437] flashing tool "wrx04" loaded.
[17:36:01.437] flashing tool "sti04" loaded.
[17:36:01.437] flashing tool "sti05" loaded.
[17:36:01.437] flashing tool "mitsukernel" loaded.
[17:36:01.437] flashing tool "mitsukernelocp" loaded.
[17:36:01.437] flashing tool "mitsubootloader" loaded.
[17:36:01.437] flashing tool "shbootmode" loaded.
[17:36:01.453] flashing tool "shaudmode" loaded.
[17:36:01.453] flashing tool "subarucan" loaded.
[17:36:01.453] flashing tool "mitsucan" loaded.
[17:36:14.125] 52680015 (92 tables) inheriting evo10base (102 tables)
[17:36:14.125] 52680018 (0 tables) inheriting 52680015 (102 tables)
[17:36:14.203] 1048576 byte image read.
[17:39:11.656] 1048576 byte image written.
[17:39:54.265] J2534 API Version: 04.04
[17:39:54.265] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[17:39:54.265] Device Firmware Version: 1.07.2597
[17:39:58.296] -- loading kernel --
[17:39:58.296] -- connecting to kernel --
[17:39:58.296] kernel get version
[17:39:58.625] ECU HW part number : 1860A979
[17:39:58.656] ECU SW part number : 1860A97902
[17:39:58.671] VIN : JA3AW86V58U047466
[17:39:58.671] -- unlocking ECU --
[17:39:58.671] starting session...
[17:39:58.953] requesting seed...
[17:39:58.953] sending key...
[17:39:59.296] -- uploading kernel --
[17:39:59.312] .
[17:39:59.328] .
[17:39:59.343] .
[17:39:59.359] .
[17:39:59.359] .
[17:39:59.375] .
[17:39:59.390] .
[17:39:59.406] .
[17:39:59.406] .
[17:39:59.421] .
[17:39:59.437] .
[17:39:59.453] .
[17:39:59.453] .
[17:39:59.468] .
[17:39:59.484] .
[17:39:59.500] .
[17:39:59.515] .
[17:39:59.515] .
[17:39:59.531] .
[17:39:59.546] .
[17:39:59.546] .
[17:39:59.546] -- connecting to kernel --
[17:39:59.546] kernel get version
[17:39:59.562] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[17:39:59.562] reading kernel comm buffer size
[17:39:59.562] comm buffer size set to 1024
[17:39:59.562] reading kernel flash buffer size
[17:39:59.562] flash buffer size set to 4096
[17:39:59.562] -- flashing image to ECU memory --
[17:39:59.968] -- comparing ECU flash memory pages to image file --
[17:39:59.968] seg start len ecu CRC32 img CRC32 same?
[17:39:59.984] FB01 00000000 00002000 0DD1921C 40A17AA6 NO
[17:39:59.984] FB02 00002000 00001000 2F74E0AC 2F74E0AC YES
[17:40:00.000] FB03 00003000 00001000 983E77B4 983E77B4 YES
[17:40:00.031] FB04 00004000 00004000 E1FD7D70 E1FD7D70 YES
[17:40:00.093] FB05 00008000 00008000 D3FDA284 D3FDA284 YES
[17:40:00.203] FB06 00010000 00010000 2455974D 2455974D YES
[17:40:00.328] FB07 00020000 00010000 695195F8 695195F8 YES
[17:40:00.437] FB08 00030000 00010000 D755F034 D755F034 YES
[17:40:00.546] FB09 00040000 00010000 32434E89 32434E89 YES
[17:40:00.671] FB10 00050000 00010000 35C372A4 35C372A4 YES
[17:40:00.781] FB11 00060000 00010000 32EDE3D3 32EDE3D3 YES
[17:40:00.906] FB12 00070000 00010000 F3F54840 F3F54840 YES
[17:40:01.015] FB13 00080000 00010000 43CF4BCE 43CF4BCE YES
[17:40:01.125] FB14 00090000 00010000 52D6CF7F 52D6CF7F YES
[17:40:01.250] FB15 000A0000 00010000 D07A764D D07A764D YES
[17:40:01.359] FB16 000B0000 00010000 1B4380E2 7979515E NO
[17:40:01.484] FB17 000C0000 00010000 DEAB7E4E DEAB7E4E YES
[17:40:01.593] FB18 000D0000 00010000 DEAB7E4E DEAB7E4E YES
[17:40:01.718] FB19 000E0000 00010000 DEAB7E4E DEAB7E4E YES
[17:40:01.828] FB20 000F0000 00010000 38439CF7 38439CF7 YES
[17:40:01.828] the image you are trying to flash contains changes to protected areas! exiting.
[17:40:01.828] interface close
[17:40:01.843] interface close
Did I something wrong?
I have totally no idea. :cry:
evoX_immo.zip
(336.26 KiB) Downloaded 298 times
napado
Users browsing this forum: No registered users and 45 guests
