speed limiter problem on 52360018
Postby jason4656 » Sun Mar 28, 2010 10:21 am
this rom inherits 52370024 in this rom i see 3 addresses for the speed limiter but only 1 of them shows in the map which i have changed but it doesnt work
in the rom we have
speed limiter @ 53062
speed limiter 2 @ 533d2
primary speed limiter @ 53fb2
i presume in ecuflash i only have access to the first one but maybe someone else can help me work out what to do to get the limiter off?
jason4656
Re: speed limiter problem on 52360018
Postby Thane » Sun Mar 28, 2010 10:43 pm
Hi Jason
You are using an incomplete definition file, use this one that will solve your problem.
52360018.xml
(22.11 KiB) Downloaded 630 times
Thane
Postby jason4656 » Mon Mar 29, 2010 1:36 am
hi,
thanks for this, what i see though is that its just setup in a different way with the same info
52360018 that you have posted inherits evo x base, 52360018 that i use, inherits 52370024.
all the content is the same, just use in a different way, the only difference i see in relevance to speed limiter is this
<table name="Speed Limiter #1" address="53062" level="4">
</table>
<table name="Speed Limiter #2" address="533d2">
</table>
<table name="Speed Limiter #3" address="53fb2">
</table>
what is Level="4"
?? thats not in my rom, but the addresses are the same, so obviously something is wrong because in reference to speed limit address, ive changed the value to be 300kmh, but it doesnt work, the other 2 speed limiter tables dont show in ecuflash.
my rom is quite modified so im trying not to just try a new one, but to find the problem
thanks
jason4656
Postby Thane » Mon Mar 29, 2010 2:22 am
Jason
Use the file I sent you, I can open all speed limters in it,
Speed limiter 1 is currently set at 190/184
Speed Limiter 2 is currently set at 190/186
Speed Limiter 3 is currently set at 180/174
Thane
Postby jason4656 » Mon Mar 29, 2010 2:28 am
ok i will have to modify with the mode23/ifmode/pcode disable values and then use this one, thank you so much, will give it a try later :)
jason4656
Postby Thane » Mon Mar 29, 2010 2:40 am
Or change your setting in Ecuflash to developer and open the greyed out files and enter the address manually
Thane
Postby jason4656 » Mon Mar 29, 2010 3:22 am
have tried that already, was in developer mode and showing all tables that are incomplete or missing and there is nothing in the greyed out tables about speed limiters?
jason4656
Postby Thane » Mon Mar 29, 2010 3:44 am
ok just copy and past to your definition file from the file i sent you, or if send it to me I will do it for you
Thane
Postby jason4656 » Thu Apr 01, 2010 6:39 am
hi, please post your evoxbase xml also using the xml above doesnt fix the problem, it shows the 3 speed limiters but also says they are inaccessible
thanks
jason4656
