EVO 9 JM8859-14
EVO 9 JM8859-14
Postby jaytech » Fri Apr 14, 2006 8:59 am
Here is version 14
evo9_version14_stock.hex
Second revision
(512 KiB) Downloaded 611 times
jaytech
Postby DarkECU » Fri May 19, 2006 2:00 pm
<ecu_struct id="8859-14" type="JM8859-14 -> 1860A465 EVO 9 USA MY06" include="">
<map name="2DBD -> Fuel Map High Octane" type="3" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6EC8" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6EA0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#2DBD" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="2EF5 -> Fuel Map Low Octane" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#2EF5" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="33E9 -> Ignition Map High Octane #1" type="3" active="1" help="Asynchronous injection compensation used briefly after engine startup." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6F2C" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6EFA" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#33E9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3599 -> Ignition Map Low Octane #1" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3599" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map High Octane" type="3" active="0" help="" >
<cols count="18" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#0" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<cols count="19" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="19" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="Engine Rev Limit" >
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #1" type="3" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane #1" type="3" active="0" help="Maximum asynchronous injection pulse width." >
</map>
<map name="68BD -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#7A64" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7A96" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#68BD" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5523 -> Ignition Map High Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5523" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="56D3 -> Ignition Map Low Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#56D3" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5A33 -> Ignition Map High Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5A33" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5BE3 -> Ignition Map Low Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5BE3" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map High Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #4" type="3" active="0" help="" >
</map>
</map>
<map name="0 -> Belch Map" type="3" active="0" help="" >
<cols count="5" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Cough Map 1" type="3" active="0" help="" >
<cols count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="24" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Squit Map" type="3" active="0" help="" >
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="30" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Flob Map" type="3" active="0" help="" >
<rows count="28" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Cough Map 2" type="3" active="0" help="" >
</map>
<map name="0 -> Splutter Map" type="3" active="0" help="" >
<cols count="26" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="15" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Wheeze Map" type="3" active="0" help="" >
<cols count="25" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="3038 -> TFCNEH3_MA" type="3" active="1" help="" >
<cols count="3" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3038" power="1" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="38F9 -> Advance DWRT (21*19) #1" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#38F9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3AA9 -> Advance DWRT (21*19) #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3AA9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5883 -> Advance DWRT (21*19) #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5883" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*19)" type="3" active="0" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*20)" type="3" active="0" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
</map>
<map name="0 -> Advance DWRT (21*19) #1" type="3" active="0" help="Maximum integral value." >
</map>
<map name="0 -> Advance DWRT (21*19) #2" type="3" active="0" help="" >
</map>
<map name="0 -> Advance DWRT (21*19) #3" type="3" active="0" help="" >
</map>
<map name="0 -> TFLICS" type="3" active="0" help="" >
<cols count="27" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="8" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Steps (Steps)" desc="Steps (Steps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TIEL" type="3" active="0" help="" >
<cols count="11" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Current (Amps)" desc="Current (Amps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TBMTHWVA1" type="3" active="0" help="" >
<cols count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="10" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> TBMTHA2" type="3" active="0" help="" >
</map>
<map name="536B -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#536B" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3050 -> Boost Limit" type="2" active="1" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#76B0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3050" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F38 -> Max Wastegate Duty - A" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#722E" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3f38" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F4E -> Max Wastegate Duty - B" type="2" active="1" help="" >
<data offset="#3f4e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F6A -> Max Wastegate Duty - C" type="2" active="1" help="" >
<data offset="#3f6a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F80 -> Boost Desired Engine Load - A" type="2" active="1" help="" >
<data offset="#3f80" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F96 -> Boost Desired Engine Load - B" type="2" active="1" help="" >
<data offset="#3f96" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3FB2 -> Boost Desired Engine Load - C" type="2" active="1" help="" >
<data offset="#3fb2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="5ECC -> AFM" type="2" active="1" help="" >
<rows count="116506" format="" func_2val="" func_val2="ngine load to be achieved by regulation of turbo boost pressure. Add 1D value 'Boost Control - Desired Engine Load Offset' to determine desired load. 200% load is approx 1.2bar of boost." offset="#3351" power="2" caption="" desc=" ()" signed="False" reverse_bytes="False"/>
<data offset="#5ecc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Max Wastegate Duty - D" type="2" active="0" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Max Wastegate Duty - E" type="2" active="0" help="" >
</map>
<map name="0 -> Max Wastegate Duty - F" type="2" active="0" help="" >
</map>
<map name="0 -> Max Wastegate Duty - G" type="2" active="0" help="" >
</map>
<map name="0 -> Boost Desired Engine Load - D" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Boost Desired Engine Load - E" type="2" active="0" help="" >
</map>
<map name="3277 -> Acceleration Enrichment" type="2" active="1" help="Asynchronous injection compensation used briefly after engine startup." >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6C26" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3277" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F20 -> Turbo Dynamics" type="2" active="1" help="" >
<rows count="17" format="%.1f" func_2val="[value]/8192" func_val2="[value]*8192" offset="#7258" power="2" caption="%" desc="Boost Error (%)" signed="False" reverse_bytes="True"/>
<data offset="#3f20" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Turbo Dynamics (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3060 -> Open Loop Load #1" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6B98" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3060" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3076 -> Open Loop Load #2" type="2" active="1" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
<data offset="#3076" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3092 -> Open Loop Throttle Low Load" type="2" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<data offset="#3092" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="30A8 -> Open Loop Throttle High Load" type="2" active="1" help="" >
<data offset="#30a8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="31D4 -> Injector battery voltage compensation" type="2" active="1" help="Maximum asynchronous injection pulse width." >
<rows count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6DF4" power="2" caption="V" desc="Battery Voltage (V)" signed="False" reverse_bytes="False"/>
<data offset="#31d4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="ms" color_dir="0" desc="Lag Time (ms)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D24 -> Desired Idle RPM - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#70C2" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3d24" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D38 -> Desired ISCV initial step position with AC off - Neutral" type="2" active="1" help="" >
<data offset="#3d38" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D4C -> Desired ISCV initial step position with AC off - Drive" type="2" active="1" help="" >
<data offset="#3d4c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D60 -> Desired ISCV initial step position with AC on - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6FDE" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3d60" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Desired Idle RPM - Drive" type="2" active="0" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Desired ISCV initial step position with AC on - Drive" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D06 -> AFM speed ?" type="2" active="1" help="" >
<rows count="21" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6DA4" power="2" caption="Hz" desc="Frequency (Hz)" signed="False" reverse_bytes="False"/>
<data offset="#2d06" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D22 -> AFM Frequency compensation" type="2" active="1" help="" >
<data offset="#2d22" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2DA2 -> AFM Air Temperature compensation" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#714A" power="2" caption="C " desc="Air Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#2da2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D7C -> AFM Pulses Per Second ?" type="2" active="1" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#2d7c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="pps" color_dir="0" desc="Pulses per second (pps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D94 -> AFM Water Temperature compensation" type="2" active="1" help="Engine Rev Limit" >
<data offset="#2d94" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3030 -> Overrun Fuel Cut-off RPM vs Coolant Temp" type="2" active="1" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data offset="#3030" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="328E -> A/F Correction Coeff for water temp" type="2" active="1" help="" >
<data offset="#328e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Percent (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32B6 -> Asynchronous Injection base pulse width against throttle angle delta" type="2" active="1" help="" >
<rows count="10" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6B7A" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#32b6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32C6 -> Asynchronous Injection limitation TPS voltage" type="2" active="1" help="" >
<data offset="#32c6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32D6 -> Asynchronous Injection coolant temp compensation coefficient" type="2" active="1" help="" >
<data offset="#32d6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32E4 -> Asynchronous Injection compensation coefficient against Ne" type="2" active="1" help="" >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#32e4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="338E -> Lean Spool: Trailing time (rich side)" type="2" active="1" help="" >
<rows count="14" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6E62" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#338e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33A2 -> Lean Spool: Trailing time (lean side)" type="2" active="1" help="" >
<data offset="#33a2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33B6 -> Lean Spool: Engine Load Threshold" type="2" active="1" help="" >
<data offset="#33b6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33CA -> Lean Spool: AFR Adjustment" type="2" active="1" help="" >
<rows count="7" format="%.1f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] / 128)" offset="#6E88" power="2" caption="AFR" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True"/>
<data offset="#33ca" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" power="1" caption="AFR" color_dir="0" desc="Fuel Map Val (AFR)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="3CF6 -> Knock control judgement boost map" type="2" active="1" help="" >
<rows count="9" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#3cf6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D06 -> Knock learning function area boost map" type="2" active="1" help="" >
<data offset="#3d06" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D3A -> Knock learning function initialise value" type="2" active="1" help="" >
<data offset="#3d3a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4E66 -> Air Inject Time" type="2" active="1" help="Engine load value that must be added to desired engine load 2D maps to determine actual desired boost profile." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7694" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#4e66" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="msec" color_dir="0" desc="Air Inject Time (msec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> ?????????" type="2" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Inj. Time Compensation" type="2" active="0" help="Maximum integral value." >
<rows count="36" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="usec" color_dir="0" desc="Fuel Inj Time Comp (usec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi Off Fan Control" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="km/h" color_dir="0" desc="Vehicle Speed (km/h)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi On Fan Control" type="2" active="0" help="" >
</map>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="degree" color_dir="0" desc="Temperature (degree)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
<map name="3D6E -> ISC D/P initial from Throttle Voltage AC Off - Neutral" type="2" active="1" help="" >
<rows count="7" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3d6e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DDA -> ISC desired position high altitude compensation" type="2" active="1" help="" >
<rows count="5" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3dda" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DEC -> ISC Error Dynamics - Neutral" type="2" active="1" help="" >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3dec" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DFC -> ISC Error Dynamics - Drive" type="2" active="1" help="" >
<data offset="#3dfc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4012 -> Fan Control - 1" type="2" active="1" help="" >
<rows count="12" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#4012" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="401E -> Fan Control - 2" type="2" active="1" help="" >
<data offset="#401e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="402A -> Fan Control - 3" type="2" active="1" help="" >
&l
DarkECU
Postby Nemis » Mon May 22, 2006 9:04 am
@ DarkECU may you attach the full definition file? (so no 1 can make error wih copy and apste ;-) )
Nemis
ok
Postby DarkECU » Mon May 22, 2006 10:49 am
all right
JM8859-14.txt
(109.21 KiB) Downloaded 531 times
DarkECU
