Help request 2000 eclipse gt mt fed spec definition
Postby MattS00 » Fri Mar 13, 2009 2:22 pm
Here is my rom from a H8 processor based eclipse. Is anyone able to make an xml definition for it?
There is already a defintion file for a 2000 eclipse gt mt, but it is probably a different rom id, as I cannot open or edit my rom with it. I can how ever open the rom that has the definition. The defined xml is number 21810021.
00_ECLIPSE_GT_MT_FED.hex
(128 KiB) Downloaded 731 times
MattS00
Re: Help request 2000 eclipse gt mt fed spec definition
Postby acamus » Mon Mar 16, 2009 10:43 pm
Your ROM is 21810022.
It should be almost the same as 21810021.
ECU Family is EM2181
acamus
Postby MattS00 » Tue Mar 17, 2009 8:38 am
Thank you.
MattS00
Postby MattS00 » Tue Mar 17, 2009 4:44 pm
I don't know if this correct, so I was debating on posting it. I am now able to view my maps, but I am leary about attempting a reflash. I WOULD REALLY LIKE FOR SOMEONE MORE EXPERIENCED TO LOOK THIS OVER BEFORE I PROCEED. This is what I did.
I used DASMH85.exe, referenced this thread http://www.club3g.com/forum/eclipse-per ... hread.html, used the defintion xml for the 21810021, and compaired my rom to the 2180021 rom. The rom id was different.
So I changed 21810021 in the xml to 21810022, renamed the xml 21810022, and then added it to the rommetadata folder.
MattS00
Postby MattS00 » Thu Mar 19, 2009 10:39 pm
Here is the defintion.
21810022.xml
(3.85 KiB) Downloaded 645 times
MattS00
