97-99 h8 based 2g eclipse ecu's
Postby thumper1151 » Mon Mar 24, 2008 9:41 am
Has there been any further progress made in being able to flash the h8 based ecu's? I know colby added the ability to read them but does does anyone have an official word on weather or not he is working on the ability to flash still? I know there are many dsmers anxiosly waiting!!
Colby if you could post an update on progress that would be great!!
thumper1151
Postby Travis » Fri Mar 28, 2008 1:19 am
Here's a BIG +1 to that.
Travis
Postby stealthfox » Tue May 20, 2008 10:38 am
+1
stealthfox
Postby AlGontsov » Sat Jun 07, 2008 2:49 am
Yes, I got a rom of USDM 99 Eclipse, done the comparsion, but can't erease the memory and start the writing...
+1!
AlGontsov
Postby xor » Sat Jun 07, 2008 8:20 am
Yes, there are attepts to find out the init code possibly for ALL mitsubishis, check it here and share your findings (except BUMPS :D )
http://www.aktivematrix.com/forum/viewtopic.php?p=4274
xor
Postby stealthfox » Fri Jun 13, 2008 10:23 am
They gotta be close. If I could send someone the stock image off my 99 GST would that help the progress any? I am a new tuner and would not be able to help alot in the diagnostic process, although I'd be more than willing to try.
stealthfox
Postby Gatecrasher » Fri Jun 13, 2008 9:32 pm
Would colby (or anyone else) post the source for his H8 read/flash kernel? If he doesn't have the time or desire to work on it, then maybe some of us can. It'd be better than starting from scratch.
Gatecrasher
Postby thumper1151 » Mon Oct 13, 2008 8:11 am
it may be able to finally flash the h8 based ecus we are still waiting on the oficial word from colby though. check out this thread http://www.dsmtuners.com/forums/tuning- ... 38-2g.html
thumper1151
Postby Travis » Mon Oct 13, 2008 9:13 am
thumper1151 wrote:it may be able to finally flash the h8 based ecus we are still waiting on the oficial word from colby though. check out this thread http://www.dsmtuners.com/forums/tuning- ... 38-2g.html
I already tried to flash my ecu with 1.38 and got the same error as before. The reason "GSXDNA" didn't get an error is because he did a "test write" (which only reads the ecu again and compares thus giving the message "flash image is identical! exiting.") and those have worked for many versions now. Once they get the definitions finished and actually try to change something it will give the error.
I tried to sign up over there to help but the thread is in a forum where newbs cant post....lame.
BTW, dsmtuners is waaaaay behind the times. I got my brother over on dsmtalk to post this stuff up a while ago. There may be more help/info there http://www.dsmtalk.com/forums/showthread.php?p=1758794#post1758794
Travis
Re: 97-99 h8 based 2g eclipse ecu's
Postby chrisgsx » Sun Jul 12, 2009 2:09 pm
The 1.3 does not work, the 2.0 has been done and works to flash 98-99. Dsmtuners.com has more info.
chrisgsx
Users browsing this forum: No registered users and 33 guests
