ok my idle problem started when i installed my gt35r, (used to have a 50 trim)
when i start my car it idles normal, but if i bearly tap the gas my afrs will dip into 8.3 and slowly come back up. Also i did a little tuning 2 weeks ago and my afrs during WOT were in the low 11s....and now all of the sudden my afrs are in the 8s at WOT...... i cant seem to figure out what the problem is. i have 680cc injectors but i have had them on the car for a year and the fuel trims were in check up until i installed this.....ive tried messing with my latency tables but it does not effect my rich idle dip.
any help will be appreciated...i cant seem to figure this out. (all i did was add the turbo, everything else stayed the same)
heres a log
http://www.mediafire.com/?7xmgtcjp0zt
and i dont have any boost leaks....
