EVO9 JM8859
Postby jaytech » Fri Apr 21, 2006 9:36 am
S54fan wrote:Anyone know what the scaling would be for the VVT map?
On JM8858-13 I know that for example the load 10 figures are 0, 0, 0, 4.8, 9.6, 9.6, 9.6, 9.6, 9.6, 9.6, 9.6, 4.8, 4.8, 4.8, 0, 0 from 500 to 7000 RPM. If I knew what these would be in hex I could search the ROM for this string?
Boost control details anyone?
On JM8859-15: Just check for the patterns on version 13 if the addresses are different.
VVT map address: 0x68BD size: 20x16
VVT load address: 0x7864 size: 20
VVT RPM address: 0x7896 size: 16
I have the boost tables for the EVO 8 ROMS still going thru the EVO 9 ROM, will get them hopefully by this weekend.
Jason
Mitsubishi ECU Specialist
jaytech
Postby S54fan » Fri Apr 21, 2006 12:26 pm
Thanks Jason. The tables from the Evo 8 would still be very interesting! :)
Postby GTODesign » Fri Apr 21, 2006 10:55 pm
TBH I've been a bit short on time for the E9 stuff lately so if anyone fancies working through these maps to see what they are, their help would be much appreciated. Please bear in mind ALL the maps mentioned below are WORK IN PROGRESS.
#3E31 216x1
#40B3 10x9
#4138 10x9
#42A5 11x16
#4361 11x16
#441D 11x16
#44D9 11x16
#4595 11x16
#4651 11x16
#47ED 10x7
#486B 7x8
#48BA 10x8
#495B 11x16
#4A17 11x16
#4AD3 11x16
#4B8F 11x16
#4C4B 11x16
#4D07 11x16
#68BD 16x20 edit - sorry, just realized this is the afore-mentioned VVT map
#AE6A 127x1
#AF1C 167x1
#B108 138x1
#B232 81x1
#B34C 106x1
I just haven't had time to work through them.
GTODesign
Postby S54fan » Mon Apr 24, 2006 1:53 am
I wondered if the first 10x9 maps was wastegate control from the shape.
Couldn't fathom any of the others from just looking at them.
MIVEC table
Postby S54fan » Mon Apr 24, 2006 3:06 am
I guessed at the scaling being in 4.8 degree steps. Axes are still the wrong way around with the version of ECU edit I'm using and I've put the load/RPM scaling in manually again.
Postby jaytech » Mon Apr 24, 2006 6:33 am
GTODesign wrote:#AE6A 127x1
#AF1C 167x1
#B108 138x1
#B232 81x1
#B34C 106x1
Those areas above are related to OBD II instruction code addresses. And some are Subroutines for the chip's on-board ATU II (Advanced Timer Unit), and DMA controller registers.
Jason
jaytech
Postby jaytech » Mon Apr 24, 2006 6:39 am
Here is how the MIVEC map looks like...
jaytech
Wastegate Max duty maps
Postby jaytech » Mon Apr 24, 2006 6:50 am
Here are the wastegate max duty info found thru disassembly:
Wastegate Max Duty #1: 3F38 16x1
Wastegate Max Duty #2: 3F4E 16x1
Wastegate Max Duty #3: 3F6A 16x1
jaytech
WG Duty
Postby S54fan » Mon Apr 24, 2006 7:16 am
Since they are maximums I would assume it wouldn't run 100% at least in the early midrange to avoid overboost. Presumably it runs closed loop control. Does the US model have a MAP sensor like the JDM and UK models?
Re: WG Duty
Postby jaytech » Mon Apr 24, 2006 7:28 am
S54fan wrote:Since they are maximums I would assume it wouldn't run 100% at least in the early midrange to avoid overboost. Presumably it runs closed loop control. Does the US model have a MAP sensor like the JDM and UK models?
It runs at 100%, it uses the boost offset value, and boost load % tables and boost error table to determine actual duty cycle. The MAP sensor is only used for EGR Flow determination on all models.
jaytech
Postby S54fan » Mon Apr 24, 2006 7:36 am
Sounds quite similar to the Subaru then?
Postby DarkECU » Fri May 19, 2006 2:05 pm
<ecu_struct id="8858-13" type="JM8858-13 -> 1860A603 EVO 9 AUS MY06" include="">
<map name="2DBD -> Fuel Map High Octane" type="3" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6FD0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6FA8" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#2DBD" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="2EF5 -> Fuel Map Low Octane" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#2EF5" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="33E9 -> Ignition Map High Octane #1" type="3" active="1" help="Asynchronous injection compensation used briefly after engine startup." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#7034" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7002" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#33E9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3599 -> Ignition Map Low Octane #1" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3599" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map High Octane" type="3" active="0" help="" >
<cols count="18" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#0" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<cols count="19" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="19" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="Engine Rev Limit" >
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #1" type="3" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane #1" type="3" active="0" help="Maximum asynchronous injection pulse width." >
</map>
<map name="69DF -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#7B2A" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7B5C" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#69DF" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="54B1 -> Ignition Map High Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#54B1" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5661 -> Ignition Map Low Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5661" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="59C1 -> Ignition Map High Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#59C1" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5B71 -> Ignition Map Low Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5B71" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="65B5 -> Ignition Map High Octane #4" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#65B5" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map High Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #4" type="3" active="0" help="" >
</map>
<map name="0 -> Belch Map" type="3" active="0" help="" >
<cols count="5" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Cough Map 1" type="3" active="0" help="" >
<cols count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="24" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Squit Map" type="3" active="0" help="" >
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="30" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Flob Map" type="3" active="0" help="" >
<rows count="28" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Cough Map 2" type="3" active="0" help="" >
</map>
<map name="0 -> Splutter Map" type="3" active="0" help="" >
<cols count="26" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="15" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Wheeze Map" type="3" active="0" help="" >
<cols count="25" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="3038 -> TFCNEH3_MA" type="3" active="1" help="" >
<cols count="3" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3038" power="1" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3AA9 -> Advance DWRT (21*19) #1" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#3AA9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5811 -> Advance DWRT (21*19) #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5811" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5D21 -> Advance DWRT (21*19) #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5D21" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*19)" type="3" active="0" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*20)" type="3" active="0" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
</map>
<map name="0 -> Advance DWRT (21*19) #1" type="3" active="0" help="Maximum integral value." >
</map>
<map name="0 -> Advance DWRT (21*19) #2" type="3" active="0" help="" >
</map>
<map name="0 -> Advance DWRT (21*19) #3" type="3" active="0" help="" >
</map>
<map name="0 -> TFLICS" type="3" active="0" help="" >
<cols count="27" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="8" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Steps (Steps)" desc="Steps (Steps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TIEL" type="3" active="0" help="" >
<cols count="11" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Current (Amps)" desc="Current (Amps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TBMTHWVA1" type="3" active="0" help="" >
<cols count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="10" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> TBMTHA2" type="3" active="0" help="" >
</map>
<map name="52F9 -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#52F9" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3050 -> Boost Limit" type="2" active="1" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#77AE" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3050" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F5C -> Max Wastegate Duty - A" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7336" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3f5c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F72 -> Max Wastegate Duty - B" type="2" active="1" help="" >
<data offset="#3f72" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F8E -> Max Wastegate Duty - C" type="2" active="1" help="" >
<data offset="#3f8e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3FA4 -> Boost Desired Engine Load - A" type="2" active="1" help="" >
<data offset="#3fa4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3FBA -> Boost Desired Engine Load - B" type="2" active="1" help="" >
<data offset="#3fba" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3FD6 -> Boost Desired Engine Load - C" type="2" active="1" help="" >
<data offset="#3fd6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="678E -> AFM" type="2" active="1" help="" >
<rows count="116506" format="" func_2val="" func_val2="ngine load to be achieved by regulation of turbo boost pressure. Add 1D value 'Boost Control - Desired Engine Load Offset' to determine desired load. 200% load is approx 1.2bar of boost." offset="#67D4" power="2" caption="" desc=" ()" signed="False" reverse_bytes="False"/>
<data offset="#678e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Max Wastegate Duty - D" type="2" active="0" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Max Wastegate Duty - E" type="2" active="0" help="" >
</map>
<map name="0 -> Max Wastegate Duty - F" type="2" active="0" help="" >
</map>
<map name="0 -> Max Wastegate Duty - G" type="2" active="0" help="" >
</map>
<map name="0 -> Boost Desired Engine Load - D" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Boost Desired Engine Load - E" type="2" active="0" help="" >
</map>
<map name="3277 -> Acceleration Enrichment" type="2" active="1" help="Asynchronous injection compensation used briefly after engine startup." >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6D2E" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3277" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F44 -> Turbo Dynamics" type="2" active="1" help="" >
<rows count="17" format="%.1f" func_2val="[value]/8192" func_val2="[value]*8192" offset="#7360" power="2" caption="%" desc="Boost Error (%)" signed="False" reverse_bytes="True"/>
<data offset="#3f44" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Turbo Dynamics (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3060 -> Open Loop Load #1" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6CA0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3060" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3076 -> Open Loop Load #2" type="2" active="1" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
<data offset="#3076" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3092 -> Open Loop Throttle Low Load" type="2" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<data offset="#3092" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="30A8 -> Open Loop Throttle High Load" type="2" active="1" help="" >
<data offset="#30a8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="31D4 -> Injector battery voltage compensation" type="2" active="1" help="Maximum asynchronous injection pulse width." >
<rows count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6EFC" power="2" caption="V" desc="Battery Voltage (V)" signed="False" reverse_bytes="False"/>
<data offset="#31d4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="ms" color_dir="0" desc="Lag Time (ms)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D48 -> Desired Idle RPM - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#71CA" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3d48" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D5C -> Desired ISCV initial step position with AC off - Neutral" type="2" active="1" help="" >
<data offset="#3d5c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D70 -> Desired ISCV initial step position with AC off - Drive" type="2" active="1" help="" >
<data offset="#3d70" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D84 -> Desired ISCV initial step position with AC on - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#70E6" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3d84" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Desired Idle RPM - Drive" type="2" active="0" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Desired ISCV initial step position with AC on - Drive" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D06 -> AFM speed ?" type="2" active="1" help="" >
<rows count="21" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6EAC" power="2" caption="Hz" desc="Frequency (Hz)" signed="False" reverse_bytes="False"/>
<data offset="#2d06" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D22 -> AFM Frequency compensation" type="2" active="1" help="" >
<data offset="#2d22" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2DA2 -> AFM Air Temperature compensation" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#7252" power="2" caption="C " desc="Air Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#2da2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D7C -> AFM Pulses Per Second ?" type="2" active="1" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#2d7c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="pps" color_dir="0" desc="Pulses per second (pps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D94 -> AFM Water Temperature compensation" type="2" active="1" help="Engine Rev Limit" >
<data offset="#2d94" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3030 -> Overrun Fuel Cut-off RPM vs Coolant Temp" type="2" active="1" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data offset="#3030" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="328E -> A/F Correction Coeff for water temp" type="2" active="1" help="" >
<data offset="#328e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Percent (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32B6 -> Asynchronous Injection base pulse width against throttle angle delta" type="2" active="1" help="" >
<rows count="10" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6C82" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#32b6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32C6 -> Asynchronous Injection limitation TPS voltage" type="2" active="1" help="" >
<data offset="#32c6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32D6 -> Asynchronous Injection coolant temp compensation coefficient" type="2" active="1" help="" >
<data offset="#32d6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="32E4 -> Asynchronous Injection compensation coefficient against Ne" type="2" active="1" help="" >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#32e4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="338E -> Lean Spool: Trailing time (rich side)" type="2" active="1" help="" >
<rows count="14" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6F6A" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#338e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33A2 -> Lean Spool: Trailing time (lean side)" type="2" active="1" help="" >
<data offset="#33a2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33B6 -> Lean Spool: Engine Load Threshold" type="2" active="1" help="" >
<data offset="#33b6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="33CA -> Lean Spool: AFR Adjustment" type="2" active="1" help="" >
<rows count="7" format="%.1f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] / 128)" offset="#6F90" power="2" caption="AFR" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True"/>
<data offset="#33ca" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" power="1" caption="AFR" color_dir="0" desc="Fuel Map Val (AFR)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="3CF6 -> Knock control judgement boost map" type="2" active="1" help="" >
<rows count="9" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#3cf6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D06 -> Knock learning function area boost map" type="2" active="1" help="" >
<data offset="#3d06" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D3A -> Knock learning function initialise value" type="2" active="1" help="" >
<data offset="#3d3a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4E3A -> Air Inject Time" type="2" active="1" help="Engine load value that must be added to desired engine load 2D maps to determine actual desired boost profile." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7792" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#4e3a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="msec" color_dir="0" desc="Air Inject Time (msec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> ?????????" type="2" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Inj. Time Compensation" type="2" active="0" help="Maximum integral value." >
<rows count="36" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="usec" color_dir="0" desc="Fuel Inj Time Comp (usec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi Off Fan Control" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="km/h" color_dir="0" desc="Vehicle Speed (km/h)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi On Fan Control" type="2" active="0" help="" >
</map>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="degree" color_dir="0" desc="Temperature (degree)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
<map name="3D92 -> ISC D/P initial from Throttle Voltage AC Off - Neutral" type="2" active="1" help="" >
<rows count="7" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3d92" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DFE -> ISC desired position high altitude compensation" type="2" active="1" help="" >
<rows count="5" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3dfe" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3E10 -> ISC Error Dynamics - Neutral" type="2" active="1" help="" >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3e10" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3E20 -> ISC Error Dynamics - Drive" type="2" active="1" help="" >
<data offset="#3e20" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4036 -> Fan Control - 1" type="2" active="1" help="" >
<rows count="12" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#4036" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4042 -> Fan Control - 2" type="2" active="1" help="" >
<data offset="#4042" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="404E -> Fan Control - 3" type="2" active="1" help="" >
DarkECU
Postby DarkECU » Fri May 19, 2006 2:07 pm
<ecu_struct id="8859-13" type="JM8859-13 -> 1860A465 EVO 9 USA MY06" include="">
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6EC8" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6EA0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
</map>
</map>
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6F2C" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6EFA" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
<map name="68BD -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#7A64" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7A96" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#68BD" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5523 -> Ignition Map High Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5523" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="56D3 -> Ignition Map Low Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#56D3" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5A33 -> Ignition Map High Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5A33" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="5BE3 -> Ignition Map Low Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5BE3" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
<map name="38F9 -> Advance DWRT (21*19) #1" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#38F9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="3AA9 -> Advance DWRT (21*19) #2" type="3" active="1" help="" >
</map>
<map name="5883 -> Advance DWRT (21*19) #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5883" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
<map name="536B -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#536B" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#76B0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
</map>
<map name="3F38 -> Max Wastegate Duty - A" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#722E" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3f38" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F4E -> Max Wastegate Duty - B" type="2" active="1" help="" >
<data offset="#3f4e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F6A -> Max Wastegate Duty - C" type="2" active="1" help="" >
<data offset="#3f6a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F80 -> Boost Desired Engine Load - A" type="2" active="1" help="" >
<data offset="#3f80" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3F96 -> Boost Desired Engine Load - B" type="2" active="1" help="" >
<data offset="#3f96" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3FB2 -> Boost Desired Engine Load - C" type="2" active="1" help="" >
<data offset="#3fb2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="5ECC -> AFM" type="2" active="1" help="" >
<rows count="116506" format="" func_2val="" func_val2="ngine load to be achieved by regulation of turbo boost pressure. Add 1D value 'Boost Control - Desired Engine Load Offset' to determine desired load. 200% load is approx 1.2bar of boost." offset="#3351" power="2" caption="" desc=" ()" signed="False" reverse_bytes="False"/>
<data offset="#5ecc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6C26" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
</map>
<map name="3F20 -> Turbo Dynamics" type="2" active="1" help="" >
<rows count="17" format="%.1f" func_2val="[value]/8192" func_val2="[value]*8192" offset="#7258" power="2" caption="%" desc="Boost Error (%)" signed="False" reverse_bytes="True"/>
<data offset="#3f20" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Turbo Dynamics (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6B98" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
</map>
</map>
</map>
</map>
<rows count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6DF4" power="2" caption="V" desc="Battery Voltage (V)" signed="False" reverse_bytes="False"/>
</map>
<map name="3D24 -> Desired Idle RPM - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#70C2" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3d24" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D38 -> Desired ISCV initial step position with AC off - Neutral" type="2" active="1" help="" >
<data offset="#3d38" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D4C -> Desired ISCV initial step position with AC off - Drive" type="2" active="1" help="" >
<data offset="#3d4c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3D60 -> Desired ISCV initial step position with AC on - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6FDE" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#3d60" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
</map>
<rows count="21" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6DA4" power="2" caption="Hz" desc="Frequency (Hz)" signed="False" reverse_bytes="False"/>
</map>
</map>
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#714A" power="2" caption="C " desc="Air Temperature (C )" signed="False" reverse_bytes="False"/>
</map>
</map>
</map>
</map>
</map>
<rows count="10" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6B7A" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
</map>
</map>
</map>
</map>
<rows count="14" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6E62" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
</map>
</map>
</map>
<rows count="7" format="%.1f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] / 128)" offset="#6E88" power="2" caption="AFR" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True"/>
</map>
</map>
</map>
</map>
<map name="4E66 -> Air Inject Time" type="2" active="1" help="Engine load value that must be added to desired engine load 2D maps to determine actual desired boost profile." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#7694" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#4e66" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="msec" color_dir="0" desc="Air Inject Time (msec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
</map>
</map>
</map>
</map>
</map>
<map name="3D6E -> ISC D/P initial from Throttle Voltage AC Off - Neutral" type="2" active="1" help="" >
<data offset="#3d6e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DDA -> ISC desired position high altitude compensation" type="2" active="1" help="" >
<data offset="#3dda" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DEC -> ISC Error Dynamics - Neutral" type="2" active="1" help="" >
<data offset="#3dec" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3DFC -> ISC Error Dynamics - Drive" type="2" active="1" help="" >
<data offset="#3dfc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="4012 -> Fan Control - 1" type="2" active="1" help="" >
<data offset="#4012" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="401E -> Fan Control - 2" type="2" active="1" help="" >
<data offset="#401e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="402A -> Fan Control - 3" type="2" active="1" help="" >
DarkECU
