Help to connect to USDM IXMR
Postby Hitokiri » Fri Jul 06, 2007 3:21 pm
I am having trouble connecting to a IX MR. I know it has been flashed before, but had no luck even with ECU Unlocker. It has to be someting simple that I am doing wrong.
Openport 1.3M installed correctly and is showing in the lower right of Ecuflash 1.30.
When I try to read from the ecu and select 2006 Evo9, all I get is "unable to connect to vehicle interface." The key should be two clicks in the acc on position right?
I thought maybe the cable was not installed right, but evoscan logs fine and checks codes fine.
Postby salex » Fri Jul 06, 2007 11:51 pm
Flash sequence is usually done in two steps:
1) Open ecuflash and read image. You should get a window asking to press OK once you've turned the key in the ignition.
2) Turn the key to ignition - not starter position. Then press OK
Since Evoscan works fine, if there is any problem it should be in your flash init connector (the white plastic cable that plugs next to the OBD port).
salex
Postby antons.bungis » Wed Jul 18, 2007 10:46 am
Hi lads :)
Cant read EDM Evo9 rom. It says error acured, please read log file.
And log file shows:
[01:42:28.203] Version 1.30.1095
[01:42:28.203] 8 memory models read.
[01:42:29.250] 146 ROM metadata models read.
[01:42:29.250] checksum module "subarudbw" loaded.
[01:42:29.250] flashing tool "wrx02" loaded.
[01:42:29.250] flashing tool "wrx04" loaded.
[01:42:29.250] flashing tool "sti04" loaded.
[01:42:29.250] flashing tool "sti05" loaded.
[01:42:29.250] flashing tool "mitsukernel" loaded.
[01:42:29.250] flashing tool "mitsukernelocp" loaded.
[01:42:29.250] flashing tool "mitsubootloader" loaded.
[01:42:42.343] sending init sequence 1 (0001)
[01:42:43.406] got 0x05 response
[01:42:43.406] sending init sequence 2
[01:42:43.421] got 0x1B response
[01:42:43.421] sending init sequence 3
[01:42:43.843] entering bootloader
[01:42:43.859] sending kernel size (0)
[01:42:43.906] sending kernel load address (0xFFFF6000)
[01:42:43.953] uploading kernel
[01:42:43.953] verifying kernel checksum response
[01:42:43.953] kernel valid
[01:42:43.968] sending init sequence 2
[01:42:44.000] got 0x1C response
[01:42:44.000] sending init sequence 3
[01:42:44.421] entering bootloader
[01:42:44.468] kernel read area: addr: 03FFFA len: 0006
[01:42:44.609] kernel rsp page: 030000
[01:42:44.609] kernel read addr: 03FFFA len: 06
[01:42:44.609] kernel rsp end
[01:42:46.640] sending init sequence 1 (0001)
could find in forum how to solve the problem, so anyone? :roll:
Cheers in Advance :wink:
antons.bungis
Postby 06rexwagon » Thu Jul 26, 2007 7:23 pm
are you running the unlocker from aktivematrix? I just read a flashed MR today.
06rexwagon
Users browsing this forum: No registered users and 67 guests
