'03 Evo IC Sprayer parameters
Postby turbrodude » Tue May 08, 2007 5:15 pm
I'm new to ECUflash and I havn't been able to find this question anywhere yet.
I'd like to be able to change the parameters for spraying the intercooler on my '03 Evo. I see them in the ROM metadata under 'misc' near the 'immobilizer' tab. But when I click on IC Relay Air Temp, I can't read the number because the window is too small. It says "2...". If I press "+" some 80 times it says "3...". Then I press "-" 100 times and it goes to "1...", so now I know that each click is 0.1 degrees C. Is there a way to see the numbers though?
Also, can you change the IC Relay Control Vehicle Speed? It doesn't seem like it will edit.
turbrodude
Postby ghoonk » Tue Aug 21, 2007 1:11 pm
This is something I am definitely interested in, especially for track application so that I can run slightly cooler charge air temps
ghoonk
Postby turbrodude » Tue Aug 21, 2007 1:48 pm
Have you tried messing with the parameters?
I have changed some of my IC Spray parameters, but somewhat blindly (for reasons described above). I have not verified that its spraying more often though.
turbrodude
