Euro Ralliart ECU ROM Definition
Postby grayw » Mon Apr 09, 2007 8:10 am
Anyone have a definition for 99270000 rom file please?
grayw
Postby S54fan » Mon Apr 09, 2007 11:34 am
Not seen this one before, did a bit of work on it then got bored, map isn't very interesting.
- <rom>
- <romid>
<xmlid>99270000</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>99270000</internalidhex>
<caseid>99270000</caseid>
<ecuid>99270000</ecuid>
<make>Mitsubishi</make>
<market>EDM</market>
<model>Evo</model>
<submodel>8Ralliart</submodel>
<year>2004</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
- <table name="High Octane Fuel Map" address="33bd">
<table name="Load" address="68b0" />
<table name="RPM" address="6888" />
</table>
- <table name="Low Octane Fuel Map" address="34d7">
</table>
- <table name="High Octane Ignition Map 1" address="39d5">
<table name="Load" address="6910" />
<table name="RPM" address="68de" />
</table>
- <table name="Low Octane Ignition Map 1" address="3b5d">
</table>
- <table name="Boost Desired Engine Load # 1" address="450a">
<table name="RPM" address="6bd4" />
</table>
- <table name="Boost Desired Engine Load # 2" address="4520">
</table>
- <table name="Boost Desired Engine Load # 3" address="4536">
</table>
- <table name="Boost Desired Engine Load # 4" address="454c">
</table>
- <table name="Max Wastegate Duty # 1" address="44b2">
</table>
- <table name="Max Wastegate Duty # 2" address="44c8">
</table>
- <table name="Max Wastegate Duty # 3" address="44de">
</table>
- <table name="Max Wastegate Duty # 4" address="44f4">
</table>
</rom>
2004 Mitsubishi Lancer EVO8 RalliArt EDM (MT) [99270000]
Postby mtcavity » Mon Apr 09, 2007 4:20 pm
XML - ROM
Year? update or post the year if it is wrong.
2004 Mitsubishi Lancer EVO8 RalliArt EDM (MT) [99270000] ROM - XML.rar
(104.78 KiB) Downloaded 483 times
mtcavity
Postby grayw » Mon Apr 09, 2007 11:46 pm
Fantastic, that works great :D
grayw
Postby nod911 » Wed May 02, 2007 11:34 am
Why would this rom have identical tables for fuel and ignition as my jdm evo8?
nod911
Postby 3gturbo » Fri May 04, 2007 12:30 pm
This is the only rom I can't get to run right so far.
3gturbo
Postby grayw » Sat May 05, 2007 8:53 am
This rom is from a Euro spec '260' VIII. It has a 4 plug ECU, not a 3 like the JDM VIII.
grayw
