Wrong Market
Wrong Market
Postby Olynth » Thu Feb 22, 2007 3:32 pm
I have got an EDM Evo9 and when i looked my base map i saw "market:USDM" and didnt understand why it's USDM Map ?
Thanks...
Olynth
Postby jeff_ro » Thu Feb 22, 2007 11:09 pm
Because you are using the wrong xml definition file. Try tu use the latest ones for the EDM cars (you may find them on the forum, hit the "search", or try here: http://forums.openecu.org/viewtopic.php?t=925 ). I had the same story for my EDM EVO 9, definition 88840016.
jeff_ro
Postby Olynth » Fri Feb 23, 2007 1:33 am
i changed all xml files to "EDM XML-88840016" which in ecuflash folder.
now its OK
thanks jeff_ro
Olynth
Postby jeff_ro » Fri Feb 23, 2007 4:51 am
Ok, but not ok. Now the only file definition you have is for the 88840016. I suggest you replace all your xml files with the xml-package containts you find in the link I gave you, otherwise the only car you could read/write is yours (assuming that you use the correct definition now).
jeff_ro
Postby Olynth » Sat Feb 24, 2007 10:42 am
I downloaded "Evo 7-8-9 XMLs - 1-29-2007.zip" and changed all XMLs.
Thanks again
Olynth
ACRONYMS SUCK
Postby mtcavity » Mon Feb 26, 2007 5:15 pm
Sorry, my bad. Fixed and reposted.
mtcavity
Users browsing this forum: No registered users and 38 guests
