Swap with JDM IX map??
Postby TKPIXMR » Tue Feb 13, 2007 2:04 pm
Hi all
I change immobilizer code to match with my car, but when i download to ECU the car won't start. Did i miss something else? please help. I know a lot of us here using JDM map as base. How do you do that?
TKPIXMR
Postby Mr. Evo IX » Tue Feb 13, 2007 6:07 pm
copy the tables to a USDM map. You cant run the JDM map on your ECU but you can copy the contents to a version 13, 14, or 15 map. Can you PM me the timing map if you have it.
Mr. Evo IX
Postby TKPIXMR » Tue Feb 13, 2007 6:59 pm
Here you go
Evo 9 JDM GT.hex
(512 KiB) Downloaded 856 times
TKPIXMR
