EVO 8 RALLIART
EVO 8 RALLIART
Postby eiu » Thu Dec 21, 2006 11:45 pm
What do oyu thing about this modified ralliart map?
i am new user and i want to know if all parameter are o.k thank
evo 8 MODIF1 ralliart.hex
(256 KiB) Downloaded 920 times
eiu
Postby eiu » Thu Dec 21, 2006 11:46 pm
xml
90550001.xml
(4.97 KiB) Downloaded 911 times
eiu
Postby Evo4Mad » Fri Dec 22, 2006 5:18 am
I thought 90550001 was a 2001 Evo7 EU Ralliart rom? its what I run in my Evo8US ecu.
but why would you run it? why not just stay stock and tune the maps for your particular car. they are soo similiar that all the Ralliart rom does is take a whole lot of safety measures and margins out.
Postby eiu » Fri Dec 22, 2006 11:46 am
how then I to make to adjust the map my car has? I am very interested and I understands what you want to say. which difference between a ralliart ecu and that of origin?
what thinks you of this case?
and which modification then I to bring to him?
is this possible to activate the anti lag?
eiu
Postby Evo4Mad » Fri Dec 22, 2006 4:45 pm
ok I'll try this rom out and let you know how I get on.
Postby nod911 » Wed May 16, 2007 3:25 pm
Does anyone get any knok with this map? From 2K to 5K t high load the timing is statically set to 14 which is up to 15 deg higher in some points than my jdm evo8 map.
Does anyone have a unmodified evo8 ralliart map they could share?
nod911
90550001
Postby BarryC. » Mon Jun 25, 2007 9:13 am
does anybody have a Definition for this rom with the IC sprayer enabled??
BarryC.
Users browsing this forum: No registered users and 35 guests
