by rutthenut » Sat Jan 27, 2007 3:27 pm
I have an 'Evo VIII 260', which is base Euro model.
Attached file (OEM EvoVIII 260 image.hex) is a copy of the settings from my ecu, believed to be standard UK spec.
Initial comparisons show the same values as the French map provided, which should be the case for this model across Europe.
However, I can see additional data from my rom file - perhaps using later release of Ecuflash?
This rom map is provided here purely for reference, if anyone is interested in the 'safe' European settings of the Evo 8, 260 model.
I'd be keen to see some FQ maps for comparison to see what they change in addition to the intake/exhaust changes of those models.
- Attachments
- OEM EvoVIII 260 image.hex
- EvoVIII 260 rom image
- (256 KiB) Downloaded 757 times
