by Danny Boy » Sun Mar 01, 2009 11:04 am
Hi Daniel,
Im Daniel too and I want to ask you something about your ROM file.
I have the same car like you 2006 Evo9 GSR with 88840013 ROM MAP.
Tell me please if you can send your stock MAP if you still have it in bin or hex format.
I want to compare it with what I have.
So then.....88840013 is older verion of 88840016?I can switch them without any problem?
Ive made a mistake sending my ECU unit to Gaetmo Germany and after that I face a big problem about the fuel consumption with is very high.(34% city and 15% outside)
Please give me your original ROM map in order to compare it with mine.
Tell me please if you`ve done some modifications to your car lately and if you do tell me what.
Maybe I can use your present MAP if this is compatible.
My modifications are:
-intake kit system is Injen and it`s a "W/Intercooling piping”
-exhaust system is Milltek with the pipe diameter of 3.00”(76,20mm) and the tailpipe of 100mm
-HKS Super SQV (Super Sequential Blow Off Valve)
-exhaust insulating wrap by Thermo-Tec for the headers
Thanks in advance!!!
