2004 WRX MTX ROM
2004 WRX MTX ROM
Postby Jeramie » Fri Jul 15, 2005 4:03 pm
Stock 2004 MTX WRX Seadan
I will get the rest of the ECU info soon and update the post.
......update
6g
22611AH792
112200-5183
12v
2004 MTX WRX - ECU.zip
(89.43 KiB) Downloaded 486 times
Jeramie
Postby ahains » Wed Jul 20, 2005 6:41 am
FYI - I did a diff of this and my MY04 Wagon ECU dump(http://forums.openecu.org/viewtopic.php?t=83) and they are 100% identical.
Not too surprising that the sedan and wagon use the same programming, but good to know anyway :)
FYI - your ECU is AH792 (from the info you have above) just like mine, and your ECU image dump is version A4TF500F (same as mine). You can see that at offset 0x200 in the test_cpu.hex file.
Thanks for posting!
-Adrian
ahains
Postby Jeramie » Wed Jul 20, 2005 7:17 am
Good info to know (Also interesting)! Thanks for taking the time to compare.
Jeramie
Users browsing this forum: No registered users and 35 guests
