I see all the up stage cobb maps but can someone please upload the map for economy mode. at $4.05 for 91 oct the hell with HP unless im at the track. yes i know :shock: $4.05 :shock: i understand, but guess what, the most affortable 91 here is ARCO at $3.87 and it is pure garbage, it knocks at idle, 3500 - 5000 rpm, and then again at 6500 rpm. so i do not care for it. Octaine boosters don't do jack, and i only have 18k miles on the car, so im not going to void warrenty with H2O or ALKY, just so i can patch up for using garbage for fuel.
Before anyone asks yes i did try to make my own map, and ive managed to only get 23mpg or so. slight boost over the stage 2 map at 18mpg.
the map i made:
pull timing, boost, low det and high det maps slightly.
i would like to see what cobb did to their map for economy, any help would be nice.
