accessport map unlock
Postby sw20matt » Fri Sep 02, 2011 6:52 pm
sorry if this is a repeatedly asked question but i could not find an answer from searching.
I have a accessport and a map that I got via e-tune by email. since then I have done a tgv delete and they said they want 25.00 to delete the codes it throws. I was wondering if anybody knew a way to remove the password and what they used to make the map? or a way to transfer it to accessTuner so that I can delete them myself?
thank you for any help
sw20matt
Re: accessport map unlock
Postby sw20matt » Fri Sep 02, 2011 7:22 pm
the maps are in .ptm extension and cant seem to find what software was used or what I can use to open them
sw20matt
Postby R & H Garage » Thu Nov 10, 2011 11:18 am
If you un-marry the accessport and then use openecu/romraider to delete the codes, you should then be able to re-marry and re-load your map using your accessport. :)
R & H Garage
Postby radsdau » Thu Nov 10, 2011 3:49 pm
.ptm is a proprietary format used by Cobb to store their tunes. It'll be a cold day in hell when Cobb release that information.
Users browsing this forum: No registered users and 51 guests
