Here is ROM image from my JDM MY06 STI Spec C Type RA (the Type RA uses the same ECU as the Spec C).
Internal ECU ID is A4TJ121C.
Offsets for ECUEdit also posted later in this thread.
Spiider wrote:The file opened perfectly for me using ecu edit.
Just make sure you convert to 192k before you open it.
XMLWRITE will make the offsets for you inside of ecu edit, when it doesn't find a definition just say yes to create one using XMLWRITE.
Spiider wrote:Just make sure you convert to 192k before you open it.
