EDM LEGACY 2.0 vs 2.0R (MT)
Postby turbohay » Sun Oct 24, 2010 5:51 am
The 2.0 has 137PS i think, and the 2.0R has 165PS, this is Model year 2004 to 2006 or 2007.
I'm wondering what the difference between these two are? Is it only the double exhaust and the ROM?
Can I buy myself a 2.0 and get tune it up to 165PS with Ecuflash?
turbohay
Re: EDM LEGACY 2.0 vs 2.0R (MT)
Postby sfaragdas » Sat Mar 05, 2011 6:56 am
hi ther is 2 diferent engines ;-)
First os SOHC the secound is DOHC
the secound have AVCS... another ingnition system... and more more diferences...
sfaragdas
Postby AmenoFils » Sat Mar 19, 2011 12:47 am
Hello,
I'm going to buy a Legacy 2.0R, and it comes with 150HP, and I saw that the previous version was 163HP but they reduced the power due to antipollution laws.
Do anybody knows what is the difference between these two engine (is it just a programming or there is some mechanical differences)
thanks in advance.
AmenoFils
Postby sfaragdas » Mon Mar 21, 2011 7:12 am
yes is few diferents:
165hp in [...] 150hp in <...>
Compression ratio [11.1] <10.2>
SECONDARY AIR PUMP [is] <is not>
different Intake valve timing and Exhaust valve timing
And the 150hp version is more ecology ;-)
sfaragdas
Postby AmenoFils » Mon Mar 21, 2011 7:19 am
Thanks for the answer.
Do you think that we can have more power with the new engine?
AmenoFils
Postby sfaragdas » Mon Mar 21, 2011 7:24 am
yes but problem is with connect to ecu...
viewtopic.php?f=19&t=4986
this is essential problem can not connect and read and write rom from ECU ... ;/
JDM engines has 200Hp when it will possible to reflash this ecu it can be between 170 from 150 and 185 from 165hp models with out mechanical change...
If you can do it tell me how can i connect with op2.o and reflash this ecu... i will be gratefuly ;-)
sfaragdas
Postby AmenoFils » Mon Mar 21, 2011 7:50 am
I didn't notice that... Somebody knows why we cannot read/write the ECU?
AmenoFils
Postby sfaragdas » Tue Mar 22, 2011 1:24 am
sfaragdas
Users browsing this forum: No registered users and 50 guests
