error message when write or read on ecuflash
Postby jeffsurnet » Sat Jul 17, 2010 8:18 pm
i have a problem :when i want to read or write on my ecu (subaru wrx2001) with ecuflash i have a error message (purgcomm failed win error 5)
i use windows xp and i tried different version of ecuflash old or latest
so i can t work i think it is a problem about my cable
i try with another pc but same...
jeff
jeffsurnet
Re: error message when write or read on ecuflash
Postby TunerTools » Sun Jul 18, 2010 5:19 am
Hi Jeff,
    What country of build is the WRX? Is this a JDM model or European model?
    Are the Windows versions you are using 32 bit or 64 bit?
    Have you already tried to uninstall and reinstall the drivers?
TunerTools
Postby jeffsurnet » Thu Jul 22, 2010 4:23 am
My sub is a french car so European model
my windows is xp 32 bit
i try to change driver, i reinstall ecuflash and drivers are on ecuflash isn t it?
then i try to reinstall my computer totaly and install ecuflash but same .....
i try with other pc on vista but same.......
help!
jeffsurnet
Postby cboles » Thu Jul 22, 2010 9:18 am
What model cable are you using? Openport 2.0?
Can you copy what the log window says here?
Postby jeffsurnet » Thu Jul 22, 2010 1:39 pm
model cable : 1.3u
log:
[00:04:42.765] Version 1.29.906
[00:04:42.781] 8 memory models read.
[00:04:44.078] Unable to find parent metadata SM5236
[00:04:44.078] ROM metadata models SM5237.xml is invalid.
[00:06:06.531] 349 ROM metadata models read.
[00:06:06.531] checksum module "subarudbw" loaded.
[00:06:06.562] flashing tool "wrx02" loaded.
[00:06:06.593] flashing tool "wrx04" loaded.
[00:06:06.593] flashing tool "sti04" loaded.
[00:06:06.593] flashing tool "sti05" loaded.
[00:06:06.593] flashing tool "mitsukernel" loaded.
[00:06:06.593] flashing tool "mitsukernelocp" loaded.
[00:06:06.593] flashing tool "mitsubootloader" loaded.
[00:06:30.593] denso02_bootloader_cmd_start
[00:06:31.828] denso02_bootloader_cmd_start
[00:06:33.046] denso02_bootloader_cmd_start
[00:06:34.265] denso02_bootloader_cmd_start
[00:06:35.484] denso02_bootloader_cmd_start
[00:06:35.921] kernel get version
when ecuflash tell me connet green connector and turno on then press quickly
i do this but the radiator fan play ....
jeff
jeffsurnet
Postby cboles » Thu Jul 22, 2010 1:49 pm
Do you also have a reflash connector on this car? Does it have 3 or 6 pin positions?
jeffsurnet wrote:model cable : 1.3u
log:
jeff
Postby Evo4Mad » Fri Jul 23, 2010 5:54 am
upgrade your ecuflash, 1.29.906 is waay too old, looks like you have been playing with your EvoX xmls, so it has got some errors loading them too. best to load latest ecuflash from scratch.
Postby jeffsurnet » Sun Jul 25, 2010 12:30 pm
ok
i install latest version of ecuflash on tactrix site and :
[22:20:46.531] EcuFlash Version 1.42.2595
[22:20:46.531] OS Version Windows XP
[22:20:46.531] Qt Version 4.5.0
[22:20:46.562] 56 memory models read.
[22:20:46.562] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[22:20:47.296] 343 ROM metadata models scanned.
[22:20:47.296] checksum module "subarudbw" loaded.
[22:20:47.296] checksum module "mitsucan" loaded.
[22:20:47.296] flashing tool "wrx02" loaded.
[22:20:47.296] flashing tool "wrx04" loaded.
[22:20:47.296] flashing tool "sti04" loaded.
[22:20:47.296] flashing tool "sti05" loaded.
[22:20:47.296] flashing tool "mitsukernel" loaded.
[22:20:47.296] flashing tool "mitsukernelocp" loaded.
[22:20:47.296] flashing tool "mitsubootloader" loaded.
[22:20:47.296] flashing tool "shbootmode" loaded.
[22:20:47.296] flashing tool "shaudmode" loaded.
[22:20:47.296] flashing tool "subarucan" loaded.
[22:20:47.296] flashing tool "mitsucan" loaded.
[22:21:06.609] Using interface OpenPort 1.3 Universal TX2BXnAP34aba5c52b71bb3ef7bf98b8ce9e61bff220e35b
[22:21:11.515] denso02_bootloader_cmd_start
[22:21:12.750] denso02_bootloader_cmd_start
[22:21:13.984] denso02_bootloader_cmd_start
[22:21:15.218] denso02_bootloader_cmd_start
[22:21:16.437] denso02_bootloader_cmd_start
[22:21:16.859] kernel get version
[22:21:17.203] interface close
same......
jeffsurnet
