MY02 Outback H6-3.0 Definition request D6HE100B
Postby megalomaniac » Sun Apr 25, 2010 4:54 am
Hi All,
I have just puchased a nice MY02 Outback H6 3.0 vdc.
I can read the rom, but cannot edit. I have tried substituting the models "close" to it in the actual ROM by hex editing, but the locations of the maps must be way off because it looks all hosed up (AFRs like 2.0 to 20 at random places, etc).
The ID is D6HE100B. I have attached the ROM.
Even just the afr ratio table would be great! It is just begging to be tuned.
Thanks,
Nick
outbackH6ORIGINAL.hex
(160 KiB) Downloaded 794 times
megalomaniac
Re: MY02 Outback H6-3.0 Definition request D6HE100B
Postby megalomaniac » Fri Apr 30, 2010 3:19 pm
Hi All,
Any help at all would be great. I am willing to pay $$ for working definitions. . ..
I have tried myself, but the rom is very strange...
Thanks,
Nick
megalomaniac
Postby megalomaniac » Fri Jul 30, 2010 3:37 pm
megalomaniac wrote:Hi All,
Thanks,
Nick
is there any plan to include this rom?
megalomaniac
Postby radsdau » Sun Aug 01, 2010 5:26 pm
megalomaniac wrote:is there any plan to include this rom?
This is not a 'normal' Subaru ROM, from my experience. I tried too but couldn't work it out in time. Sorry- I can't help on this one.
My next best suggestion (which may actually be a really bad one) is to find a ROM for a similar vehicle that is supported, and see how it goes. You may end up with a bricked ECU or a broken engine however, so do so at your own risk.
Postby vaccine » Mon Aug 02, 2010 10:08 pm
i have an ADM 01 Outback that i am trying to reverse as well.
i have found 2 fuel tables and 5 timing tables. and heaps of others with unknown intent.
I had a quick look at your ROM and found the same table at a slightly different offset.
i have trialed with sucess flashing mine with fuel and timing, so yours should work as well.
no idea on the load and how its calc'd as its SD, so i just leave it as g/rev as a reference.
i just have to figure out how to save the new def i create in ecuFlash. :(
then i can post the xml file and you can play.
i have got a bit carried away with my outback. :twisted:
http://forum.liberty.asn.au/viewtopic.php?f=10&t=7411
vaccine
Postby vaccine » Wed Aug 04, 2010 12:27 am
Definition file built in ecuFlash for your EDM Outback. Values are the same as my ADM outback.
Not sure exactly how the timing is working with the different tables.
For fuel i just changed the A and B tables to be the same. Works well.
I am running fuel around 12.8 and a little extra timing for our 98octane.
Does anyone else want to double check that what i have done is correct??
D6HE100B.xml
(3.44 KiB) Downloaded 750 times
vaccine
Postby radsdau » Thu Aug 05, 2010 3:56 pm
@vaccine: thanks for posting that! It's really helpful. I'm not sure how those ROMs are structured, looks a bit odd to me.
Well done.
Postby vaccine » Thu Aug 05, 2010 7:27 pm
i didnt define the other 9 table i found , as i have no idea what they are.
couple look really funky. like an SD table or somthing else maybe.
i have them defined in the defs for my ADM outback, same on the EDM, will post tonight.
vaccine
Postby underpressure » Sun Jan 09, 2011 4:38 pm
Any updates or progress on this definition?
underpressure
Postby vaccine » Sun Jan 23, 2011 12:37 pm
i sold the outback and built a gc8 track car. 8)
i think elevenpoint7five was going to be looking into the ROM when time permitted.
vaccine
Users browsing this forum: No registered users and 23 guests
