I have a customer with a subaru STI 2.5 2005, the customer lives in Canary island and i'm not sure the subaru market, can be a JDM or EDM.
I tryed with two differents laptops with ecuflash 1.42 version and openport 2.0 cable.
The ecuflash try to read the ecu but does some tries but then close the application.
I read some post here and i found a process to read
1. Install the FLASH connector under the dash. The one used to flash.
2. Then turn ignition to ON position. Leave it that way until indicate to turn off.
3. Connect the green test mode connectors.
4. Open ECUFLASH program.
5. Make a ECU read try. Don´t touch the ignition position. Leave it as before, ON. You´ll see the same problem until this step. Don´t worry. No connection yet.
6. Now you turn ignition to OFF position.
7. Make a ECU read again. But now you follow the screen instructions.
7.1 Select the Subaru Model you want to read from.
7.2 A popup window will show.
7.3 Turn ON the ignition.
7.4 Click then OK.
I'm going to try today but if anyone can give any idea would be great and i will be very pleased
