UK300 immo, install on EU WRX2001
Postby pavlik1 » Fri Oct 16, 2009 11:58 am
Hello,
I just got ECU from UK300 with the idea to use it with openecu on my 2001 bug-eye.
The numbers on the both ECU are 100% identical
Unfortunately when I connect the UK300 ECU and try to start the engine, it didn't fire and the red key on the dash light.
With the original ECU the car start immediately. It also start with the metal part of the key and the bottom plastic.
I am not sure if in the car I have immo. will try to start only with the metal part of the key - seems not easy to remove it from the plastic.
What I have to do in order to use the new ecu?
pavlik1
Re: UK300 immo, install on EU WRX2001
Postby pavlik1 » Thu Oct 22, 2009 6:26 am
pavlik1
