Ecuflash 1.2 success
Postby Freon » Sat Apr 08, 2006 5:48 pm
Worked like a charm first try. Did not have to use the flash block, just the green connector.
A2ZJ500J
04_usdm_sti.bin
(512 KiB) Downloaded 1559 times
Postby ev8siv3 » Sat Apr 08, 2006 5:58 pm
512kb?
ev8siv3
Postby Freon » Sat Apr 08, 2006 6:19 pm
Correct...
Postby Freon » Sun Apr 09, 2006 10:08 am
Postby MRF582 » Wed Apr 19, 2006 2:15 pm
Any more updates on this? I am currently trying to figure out fuel map A.
#5C208 with a 4byte hi-lo seems to make the numbers look somewhat...
I encourage you to update your findings so I am not looking for something you've already found.
toAirFlow16= [value]*300/65536
toAirflow32 = [value]*300/(what number goes here)?
MRF582
Postby AlanG » Fri Apr 21, 2006 7:15 am
edit: nvm, figured it out... :oops:
AlanG
