Can EcuFlash Subaru 2.0 BoxerDiesel tune (EUDM)?
Postby Rally-fan » Thu Apr 02, 2009 11:16 am
Is there already software that's can be used tot tune Subaru 2.0d Boxerdiesel (engine found in Legacy ,Impreza and Forester 2.0d Boxer-Diesel) ?
Rally-fan
Re: Can EcuFlash Subaru 2.0 BoxerDiesel tune (EUDM)?
Postby merchgod » Thu Apr 02, 2009 11:47 am
You would need to attempt to pull one of those ROMs using Ecuflash and the OP 2.0 cable and then submit for inclusion into a future RomRaider/Ecuflash def update.
It may be that they use a different ECU/processor and Ecuflash will not be able to pull it. One guy attempted it before on a forester diesel but didn't have any luck but didn't spend much time on it. Other than that, no one else has tried.
merchgod
Postby remapping » Thu May 13, 2010 11:22 pm
In standard way it won't be possible. Different ECU structure though :)
remapping
Postby Jochen_145 » Thu Jun 03, 2010 7:59 am
What kind of processor does the Diesel-ECU uses ?
The same one the the latest petrol ECU ?
Then maybe a bool-loader can help?!
Btw.:
A Subaru dealer told, the standart Subaru diagnostic tester got no update to communicate with the Diesel-ECU.
Not for diagnostic and also not for falshing :shock:
German OpenSource-tool FreeSSM is able to communicate with Boxer-Diesel.
Maybe this can give hints to update ECUFlash/RomRaider for diagnostic ?
Jochen_145
