2006 2.5L STI EU Not reading
Postby sms tuner » Fri Nov 28, 2008 3:13 am
Hi,
I am trying to read the ROM on a 2006 STI 2.5L but i cant. i opened the Passenger Kick Panel and found the Green Plug already connected and tried to do it with the plug conected and disconnected but every time i get the following message:
[17:38:29.737] Version 1.38.2080
[17:38:29.737] 11 memory models read.
[17:38:29.784] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:38:32.857] 264 ROM metadata models scanned.
[17:38:32.857] checksum module "subarudbw" loaded.
[17:38:32.857] flashing tool "wrx02" loaded.
[17:38:32.857] flashing tool "wrx04" loaded.
[17:38:32.857] flashing tool "sti04" loaded.
[17:38:32.857] flashing tool "sti05" loaded.
[17:38:32.857] flashing tool "mitsukernel" loaded.
[17:38:32.857] flashing tool "mitsukernelocp" loaded.
[17:38:32.857] flashing tool "shbootmode" loaded.
[17:38:32.904] flashing tool "shaudmode" loaded.
[17:38:32.904] flashing tool "subarucan" loaded.
[17:38:48.936] Using interface OpenPort 1.3 Universal TX25IvK69687f6c9235423d5075f5e3181d874ea179212ec
[17:38:51.339] kernel get version
[17:38:51.733] SSM2 init
[17:38:51.990] SSM2 ECU ID is 4D 42 59 40 06
[17:38:52.086] Requesting Seed...
[17:38:52.138] Sending Key...
[17:38:52.823] interface close
[17:39:42.625] Using interface OpenPort 1.3 Universal TX25IvK69687f6c9235423d5075f5e3181d874ea179212ec
[17:40:08.467] kernel get version
[17:40:08.857] SSM2 init
[17:40:09.122] SSM2 ECU ID is 4D 42 59 40 06
[17:40:09.216] Requesting Seed...
[17:40:09.263] Sending Key...
[17:40:09.902] interface close
[17:43:26.269] Using interface OpenPort 1.3 Universal TX25IvK69687f6c9235423d5075f5e3181d874ea179212ec
[17:44:17.786] kernel get version
[17:44:18.176] SSM2 init
[17:44:18.441] SSM2 ECU ID is 4D 42 59 40 06
[17:44:18.519] Requesting Seed...
[17:44:18.582] Sending Key...
[17:44:19.221] interface close
Please help.
sms tuner
Postby sms tuner » Sat Nov 29, 2008 4:28 pm
Anyone please
sms tuner
Postby radsdau » Sun Nov 30, 2008 3:47 pm
Is the ECU locked?
Postby korhan » Fri Dec 05, 2008 5:49 pm
i guess you have ppp. ppp uses the same lock with ecutek and map is also made by ecutek.
korhan
Postby sms tuner » Wed Dec 10, 2008 1:56 pm
its a bone stock EU Car. please help
sms tuner
Postby sms tuner » Thu Dec 11, 2008 4:00 pm
Anyone Please.
sms tuner
Re: 2006 2.5L STI EU Not reading
Postby Jon [in CT] » Sun Dec 14, 2008 11:24 am
sms tuner wrote:i opened the Passenger Kick Panel and found the Green Plug already connected ...
Then you need to find the second pair of green connectors, maybe below driver's side dashboard.
Postby sms tuner » Tue Dec 16, 2008 2:17 am
Thank you for your replay. Can someone elaborate on the Connector things. like what is the color of the connector and the location, and if possible a proper procedure that explains what to do exactly.
Regards,
sms tuner
Postby AlGontsov » Mon Dec 22, 2008 10:39 am
Subaru has 2 green connectors, 1 of them already together, the 2nd one you should find under the plastic cover near the doors (check both passenger and driver), in the passenger feets under the carpet, under the dashboard... then join the 2nd pair, and don't forget to press "read" in the 1st seconds after turning "on" of the ignition, otherwise reading will be failed.
AlGontsov
Postby sms tuner » Tue Dec 23, 2008 11:35 pm
Thank you Sir. That was really helpful.
Chears,
sms tuner
Users browsing this forum: No registered users and 17 guests
