Hi guys,
Had an Impreza UK300 'bugeye' special edition in the other day. The Tactrix cable wouldn't read the ecu, but should it ?
The only strange thing is that this car had a Prodrive GEMS daughterboard installed inside the ECU. All this does is fools the map sensor so that you can run higher boost for a time period, but wondered if it would prevent the Tactrix cable\ECUFlash reading the ecu.
Should we be able to tune this car ?
It's one of these http://www.carfolio.com/specifications/ ... ?car=81620
