BAD test write with Ecuflash V1.39 EDM 08 STI/EDM 07 FXT+OP2
Postby hmanxx » Thu Oct 16, 2008 5:10 am
Friend did 2 test write with EDM MY07 FXT and EDM MY08 STI..with test write error.
I have no problem writing to EDM MY08 LegacyGT.A2UG001G
The only difference i spotted is I have OP2.0 FW 1.01.2145 where his OP2.0 FW is 1.00.2038.
I suspect the problem is due to device(OP2.0) using old FW .Will get friend to allow OP2.0 FW upgrade before test writing again.
If the issue is really due to the OP2.0 old firmware then there will have loophole for the failure to fall through..as the FW upgrade screen on OP2.0 is not clear, if user choose to ignore or pressing any key..it may skip the OP2.0 FW upgrade..
MY08 STI Error
16:37:55.968] AZ1G201G (264 tables) inheriting 32BITBASE (662 tables)
[16:50:56.671] 1048576 byte image written.
[16:56:36.875] 1048576 byte image written.
[16:56:43.562] J2534 API Version: 04.04
[16:56:43.562] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[16:56:43.562] Device Firmware Version: 1.00.2038
[16:56:46.484] kernel get version
[16:56:46.890] SSM2 init
[16:56:46.953] SSM2 ECU ID is 5A 42 78 41 07
[16:56:47.000] Requesting Seed...
[16:56:47.093] Sending Key...
[16:56:49.734] kernel get version
[16:56:49.765] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[16:56:49.765] reading kernel comm buffer size
[16:56:49.796] comm buffer size set to 2048
[16:56:49.796] reading kernel flash buffer size
[16:56:49.843] flash buffer size set to 4096
[16:56:49.843] Test flashing image to ECU memory...
[16:56:50.250] comparing ECU flash memory pages to image file
[16:56:50.250] seg  start    len        ecu CRC32    img CRC32  same?
[16:56:50.296] FB01 00000000 00001000   73527363     73527363     YES
[16:56:50.328] FB02 00001000 00001000   750D1713     750D1713     YES
[16:56:50.375] FB03 00002000 00001000   8F89A40F     8F89A40F     YES
[16:56:50.421] FB04 00003000 00001000   304BCC1F     304BCC1F     YES
[16:56:50.468] FB05 00004000 00001000   3E38B607     3E38B607     YES
[16:56:50.500] FB06 00005000 00001000   4C28F96B     4C28F96B     YES
[16:56:50.531] FB07 00006000 00001000   C8C6ACEB     C8C6ACEB     YES
[16:56:50.578] FB08 00007000 00001000   240A2703     240A2703     YES
[16:56:50.734] FB09 00008000 00018000   6209F40B     6209F40B     YES
[16:56:50.921] FB10 00020000 00020000   5812B87A     5812B87A     YES
[16:56:51.109] FB11 00040000 00020000   D0B34198     D0B34198     YES
[16:56:51.296] FB12 00060000 00020000   88114BED     8F4D49AC      NO
[16:56:51.500] FB13 00080000 00020000   7999FB4C     7999FB4C     YES
[16:56:51.703] FB14 000A0000 00020000   7B3EE44A     7B3EE44A     YES
[16:56:51.906] FB15 000C0000 00020000   80510589     745943AC      NO
[16:56:52.093] FB16 000E0000 00020000   1759491B     7FDC150B      NO
[16:56:52.093] kernel flash disable
[16:56:52.140] kernel write flash buffer addr: 000FF000 len: 00000800
[16:57:00.125] kernel write flash buffer addr: 000FF000 len: 00000800
[16:57:08.078] kernel write flash buffer addr: 000FF000 len: 00000800
[16:57:16.031] failure in flashing block
[16:57:16.031] kernel flash disable
[16:57:16.109] interface close
[16:57:16.203] interface close
EDM 07 FXT
[16:10:06.234] Version 1.39.2152
[16:10:06.250] 19 memory models read.
[16:10:06.250] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[16:10:06.406] 318 ROM metadata models scanned.
[16:10:06.406] checksum module "subarudbw" loaded.
[16:10:06.406] flashing tool "wrx02" loaded.
[16:10:06.406] flashing tool "wrx04" loaded.
[16:10:06.406] flashing tool "sti04" loaded.
[16:10:06.406] flashing tool "sti05" loaded.
[16:10:06.406] flashing tool "mitsukernel" loaded.
[16:10:06.406] flashing tool "mitsukernelocp" loaded.
[16:10:06.406] flashing tool "shbootmode" loaded.
[16:10:06.406] flashing tool "shaudmode" loaded.
[16:10:06.406] flashing tool "subarucan" loaded.
[16:10:14.562] A8DK100P (249 tables) inheriting 32BITBASE (662 tables)
[16:10:14.875] 1048576 byte image read.
[16:10:34.671] J2534 error [device not responding].
[16:10:34.671] unable to connect to vehicle interface.
[16:10:34.671] interface close
[16:10:44.000] J2534 API Version: 04.04
[16:10:44.000] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[16:10:44.000] Device Firmware Version: 1.00.2038
[16:10:48.703] kernel get version
[16:10:49.093] SSM2 init
[16:10:49.171] SSM2 ECU ID is 4E 42 50 40 07
[16:10:49.203] Requesting Seed...
[16:10:49.265] Sending Key...
[16:10:51.796] kernel get version
[16:10:51.843] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[16:10:51.843] reading kernel comm buffer size
[16:10:51.890] comm buffer size set to 2048
[16:10:51.890] reading kernel flash buffer size
[16:10:51.937] flash buffer size set to 4096
[16:10:51.937] Test flashing image to ECU memory...
[16:10:52.343] comparing ECU flash memory pages to image file
[16:10:52.343] seg  start    len        ecu CRC32    img CRC32  same?
[16:10:52.390] FB01 00000000 00001000   DEE001EE     DEE001EE     YES
[16:10:52.453] FB02 00001000 00001000   EA035F4B     EA035F4B     YES
[16:10:52.484] FB03 00002000 00001000   78F08C73     78F08C73     YES
[16:10:52.515] FB04 00003000 00001000   96FA847C     96FA847C     YES
[16:10:52.593] FB05 00004000 00001000   73F7C796     73F7C796     YES
[16:10:52.625] FB06 00005000 00001000   CD290BC1     CD290BC1     YES
[16:10:52.671] FB07 00006000 00001000   A2F5C6E9     A2F5C6E9     YES
[16:10:52.703] FB08 00007000 00001000   8ACA91E5     8ACA91E5     YES
[16:10:52.984] FB09 00008000 00018000   B9C0D8A1     B9C0D8A1     YES
[16:10:53.343] FB10 00020000 00020000   6079FBC7     6079FBC7     YES
[16:10:53.703] FB11 00040000 00020000   FEF0E49B     FEF0E49B     YES
[16:10:54.062] FB12 00060000 00020000   75764D57     75764D57     YES
[16:10:54.437] FB13 00080000 00020000   34298D92     34298D92     YES
[16:10:54.812] FB14 000A0000 00020000   C8A92D0F     C8A92D0F     YES
[16:10:55.187] FB15 000C0000 00020000   9CF98368     39E87B57      NO
[16:10:55.531] FB16 000E0000 00020000   900930B4     0310E562      NO
[16:10:55.546] kernel flash disable
[16:10:55.609] kernel write flash buffer addr: 000FF000 len: 00000800
[16:11:03.578] kernel write flash buffer addr: 000FF000 len: 00000800
[16:11:11.546] kernel write flash buffer addr: 000FF000 len: 00000800
[16:11:19.515] failure in flashing block
[16:11:19.515] kernel flash disable
[16:11:19.609] interface close
[16:11:19.703] interface close
[16:12:00.875] J2534 API Version: 04.04
[16:12:00.875] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[16:12:00.875] Device Firmware Version: 1.00.2038
[16:12:16.687] kernel get version
[16:12:17.093] SSM2 init
[16:12:17.156] SSM2 ECU ID is 4E 42 50 40 07
[16:12:17.187] Requesting Seed...
[16:12:17.250] Sending Key...
[16:12:19.484] kernel get version
[16:12:19.515] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[16:12:19.515] reading kernel comm buffer size
[16:12:19.546] comm buffer size set to 2048
[16:12:19.546] reading kernel flash buffer size
[16:12:19.593] flash buffer size set to 4096
[16:12:19.593] Test flashing image to ECU memory...
[16:12:20.000] comparing ECU flash memory pages to image file
[16:12:20.000] seg  start    len        ecu CRC32    img CRC32  same?
[16:12:20.046] FB01 00000000 00001000   DEE001EE     DEE001EE     YES
[16:12:20.109] FB02 00001000 00001000   EA035F4B     EA035F4B     YES
[16:12:20.156] FB03 00002000 00001000   78F08C73     78F08C73     YES
[16:12:20.203] FB04 00003000 00001000   96FA847C     96FA847C     YES
[16:12:20.234] FB05 00004000 00001000   73F7C796     73F7C796     YES
[16:12:20.265] FB06 00005000 00001000   CD290BC1     CD290BC1     YES
[16:12:20.312] FB07 00006000 00001000   A2F5C6E9     A2F5C6E9     YES
[16:12:20.343] FB08 00007000 00001000   8ACA91E5     8ACA91E5     YES
[16:12:20.625] FB09 00008000 00018000   B9C0D8A1     B9C0D8A1     YES
[16:12:21.000] FB10 00020000 00020000   6079FBC7     6079FBC7     YES
[16:12:21.375] FB11 00040000 00020000   FEF0E49B     FEF0E49B     YES
[16:12:21.750] FB12 00060000 00020000   75764D57     75764D57     YES
[16:12:22.109] FB13 00080000 00020000   34298D92     34298D92     YES
[16:12:22.484] FB14 000A0000 00020000   C8A92D0F     C8A92D0F     YES
[16:12:22.859] FB15 000C0000 00020000   9CF98368     39E87B57      NO
[16:12:23.234] FB16 000E0000 00020000   900930B4     0310E562      NO
[16:12:23.234] kernel flash disable
[16:12:23.281] kernel write flash buffer addr: 000FF000 len: 00000800
[16:12:31.281] kernel write flash buffer addr: 000FF000 len: 00000800
[16:12:39.250] kernel write flash buffer addr: 000FF000 len: 00000800
[16:12:47.218] failure in flashing block
[16:12:47.218] kernel flash disable
[16:12:47.312] interface close
[16:12:47.390] interface close
hmanxx
Postby hmanxx » Sat Oct 18, 2008 4:50 am
Issue resolved after OP2.0 FW upgrade to v1.01.2045..
hmanxx
Postby dawnduran » Sat Nov 01, 2008 5:14 am
Where I find the Firmware?
Where I could download it?
How I can update Firmware Openport2.0?
dawnduran
Postby Jon [in CT] » Sat Nov 01, 2008 11:15 am
It's part of EcuFlash 1.40, which is available at http://www.openecu.org/index.php?title=EcuFlash.
