EcuFlash 1.38 + OP2.0 Is not flashing 08 STi
Postby ev8siv3 » Sat Oct 04, 2008 6:24 am
It will not get past 47%!
[09:20:12.803] Version 1.38.2080
[09:20:12.805] 11 memory models read.
[09:20:12.806] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash 1.38/rommetadata
[09:20:12.963] 356 ROM metadata models scanned.
[09:20:12.964] checksum module "subarudbw" loaded.
[09:20:12.964] flashing tool "wrx02" loaded.
[09:20:12.964] flashing tool "wrx04" loaded.
[09:20:12.964] flashing tool "sti04" loaded.
[09:20:12.964] flashing tool "sti05" loaded.
[09:20:12.964] flashing tool "mitsukernel" loaded.
[09:20:12.964] flashing tool "mitsukernelocp" loaded.
[09:20:12.964] flashing tool "shbootmode" loaded.
[09:20:12.965] flashing tool "shaudmode" loaded.
[09:20:12.965] flashing tool "subarucan" loaded.
[09:20:19.240] AZ1G201I (313 tables) inheriting 32BITBASE (662 tables)
[09:20:19.272] AZ1G202I (0 tables) inheriting AZ1G201I (662 tables)
[09:20:19.314] 1048576 byte image read.
[09:20:31.880] kernel get version
[09:20:32.144] SSM2 init
[09:20:32.196] SSM2 ECU ID is 69 12 78 30 07
[09:20:32.218] Requesting Seed...
[09:20:32.261] Sending Key...
[09:20:34.681] kernel get version
[09:20:34.703] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.05
[09:20:34.703] reading kernel comm buffer size
[09:20:34.725] comm buffer size set to 2048
[09:20:34.725] reading kernel flash buffer size
[09:20:34.747] flash buffer size set to 4096
[09:20:34.747] Flashing image to ECU memory...
[09:20:35.147] comparing ECU flash memory pages to image file
[09:20:35.147] seg start len ecu CRC32 img CRC32 same?
[09:20:35.147] kernel CRC32 area: addr: 00000000 len: 00001000
[09:20:35.179] FB01 00000000 00001000 4D2E7C30 4D2E7C30 YES
[09:20:35.179] kernel CRC32 area: addr: 00001000 len: 00001000
[09:20:35.211] FB02 00001000 00001000 750D1713 750D1713 YES
[09:20:35.211] kernel CRC32 area: addr: 00002000 len: 00001000
[09:20:35.233] FB03 00002000 00001000 362C6FB2 362C6FB2 YES
[09:20:35.233] kernel CRC32 area: addr: 00003000 len: 00001000
[09:20:35.265] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[09:20:35.265] kernel CRC32 area: addr: 00004000 len: 00001000
[09:20:35.297] FB05 00004000 00001000 0FC6CCFA 0FC6CCFA YES
[09:20:35.297] kernel CRC32 area: addr: 00005000 len: 00001000
[09:20:35.329] FB06 00005000 00001000 25B7356F 25B7356F YES
[09:20:35.329] kernel CRC32 area: addr: 00006000 len: 00001000
[09:20:35.351] FB07 00006000 00001000 F2EE12F0 F2EE12F0 YES
[09:20:35.351] kernel CRC32 area: addr: 00007000 len: 00001000
[09:20:35.373] FB08 00007000 00001000 A9551E5F A9551E5F YES
[09:20:35.373] kernel CRC32 area: addr: 00008000 len: 00018000
[09:20:35.526] FB09 00008000 00018000 26BACF35 26BACF35 YES
[09:20:35.526] kernel CRC32 area: addr: 00020000 len: 00020000
[09:20:35.709] FB10 00020000 00020000 0C161839 0C161839 YES
[09:20:35.709] kernel CRC32 area: addr: 00040000 len: 00020000
[09:20:35.901] FB11 00040000 00020000 8F59A548 8F59A548 YES
[09:20:35.901] kernel CRC32 area: addr: 00060000 len: 00020000
[09:20:36.093] FB12 00060000 00020000 4CEFB6D0 4CEFB6D0 YES
[09:20:36.093] kernel CRC32 area: addr: 00080000 len: 00020000
[09:20:36.275] FB13 00080000 00020000 410AA846 410AA846 YES
[09:20:36.275] kernel CRC32 area: addr: 000A0000 len: 00020000
[09:20:36.458] FB14 000A0000 00020000 67AD7196 67AD7196 YES
[09:20:36.461] kernel CRC32 area: addr: 000C0000 len: 00020000
[09:20:36.648] FB15 000C0000 00020000 7AA97E67 BCA99C14 NO
[09:20:36.648] kernel CRC32 area: addr: 000E0000 len: 00020000
[09:20:36.830] FB16 000E0000 00020000 7E1C74AC C867D09D NO
[09:20:36.830] kernel flash enable
[09:20:36.852] kernel blank flash page: addr: 000E0000
ev8siv3
Postby merchgod » Sat Oct 04, 2008 7:45 am
Do you have any 3rd party firewall like ZoneAlarm installed?
merchgod
Postby TheShad0w » Sat Oct 04, 2008 7:47 am
I have the same issue...
TheShad0w
Postby ev8siv3 » Sat Oct 04, 2008 11:14 am
merchgod wrote:Do you have any 3rd party firewall like ZoneAlarm installed?
No firewalls whatsoever.
ev8siv3
Postby merchgod » Sat Oct 04, 2008 11:51 am
Sent an email to Colby about this - others have also reported the same problem.
merchgod
Postby hmanxx » Sun Oct 05, 2008 4:26 am
My friend who is trying to reflash a CANBUS EDM Forester MY07 with OP2.0 got into trouble..on test write..working fine..however once actual write started..showing alot of error then repeated tried yield no result..eventually shutdown the engine ..
Worst come on..car cant start anymore..he is contacting Colby for recovery service.
hmanxx
Postby ev8siv3 » Sun Oct 05, 2008 5:06 am
merchgod wrote:Sent an email to Colby about this - others have also reported the same problem.
Has Colby responded yet? Seeing that some are having ECU Failures already this may spread out of control quickly.
ev8siv3
Postby merchgod » Sun Oct 05, 2008 6:17 am
ev8siv3 wrote:Has Colby responded yet? Seeing that some are having ECU Failures already this may spread out of control quickly.
He said he was out of town until today. He has not responded yet. None of the users that have had problems so far have bricked their ECU, until hmanxx's post. Hmanxx - did your friend try disconnecting the battery?
I'm not sure what to do - I can pull the Ecuflash defs but I'm pretty sure they are not the cause of these problems as they have nothing to do with flashing other than selecting the flash method, which, for CAN vehicles, there's only one - subarucan and they are all correct in the defs.
EDIT: I put warnings not to flash CAN ECUs in the Ecuflash def posts and also in the big OP 2.0 thread at Nasioc. I'll respond to this post as well as the one on Nasioc once I hear something from Colby.
merchgod
Postby hmanxx » Sun Oct 05, 2008 9:20 am
ECU ID is A8DK100P,file editing was done through ECuflash.
Tried soft/hardware reset with battery terminal unplug and drain out charge..however the OP2.0 cant recognize the ecu anymore..
hmanxx
Postby merchgod » Sun Oct 05, 2008 9:26 am
do you have the Ecuflash log of the failure?
merchgod
Postby mgv101 » Sun Oct 05, 2008 5:52 pm
similar problem here while attempting a test write.
It got stuck at the same point but attempts to continue anyway slowing way down and giving a ton of error messages in the log. It also said the flash was completed successfully at the end :?.
Hearing what happened hmanxx's friend, I feel lucky that I didn't actually attempt an actual write.
here's my log:
[19:58:22.829] Version 1.38.2080 [19:58:22.837] 11 memory models read.
[19:58:22.838] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[19:58:23.303] 306 ROM metadata models scanned.
[19:58:23.303] checksum module "subarudbw" loaded.
[19:58:23.304] flashing tool "wrx02" loaded.
[19:58:23.304] flashing tool "wrx04" loaded.
[19:58:23.304] flashing tool "sti04" loaded.
[19:58:23.305] flashing tool "sti05" loaded.
[19:58:23.305] flashing tool "mitsukernel" loaded.
[19:58:23.305] flashing tool "mitsukernelocp" loaded.
[19:58:23.305] flashing tool "shbootmode" loaded.
[19:58:23.308] flashing tool "shaudmode" loaded.
[19:58:23.308] flashing tool "subarucan" loaded.
[19:58:37.973] A2TB100A (264 tables) inheriting 32BITBASE (662 tables)
[19:58:38.073] 1048576 byte image read.
[19:59:02.365] kernel get version
[19:59:02.610] SSM2 init
[19:59:02.661] SSM2 ECU ID is 52 04 50 40 07
[19:59:02.682] Requesting Seed...
[19:59:02.724] Sending Key...
[19:59:05.027] kernel get version
[19:59:05.058] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.05
[19:59:05.058] reading kernel comm buffer size
[19:59:05.089] comm buffer size set to 2048
[19:59:05.091] reading kernel flash buffer size
[19:59:05.123] flash buffer size set to 4096
[19:59:05.123] Test flashing image to ECU memory...
[19:59:05.523] comparing ECU flash memory pages to image file
[19:59:05.523] seg start len ecu CRC32 img CRC32 same?
[19:59:05.523] kernel CRC32 area: addr: 00000000 len: 00001000
[19:59:05.554] FB01 00000000 00001000 AE6D8A07 AE6D8A07 YES
[19:59:05.554] kernel CRC32 area: addr: 00001000 len: 00001000
[19:59:05.586] FB02 00001000 00001000 EA035F4B EA035F4B YES
[19:59:05.586] kernel CRC32 area: addr: 00002000 len: 00001000
[19:59:05.618] FB03 00002000 00001000 21A08FCB 21A08FCB YES
[19:59:05.618] kernel CRC32 area: addr: 00003000 len: 00001000
[19:59:05.650] FB04 00003000 00001000 EB2F3706 EB2F3706 YES
[19:59:05.650] kernel CRC32 area: addr: 00004000 len: 00001000
[19:59:05.692] FB05 00004000 00001000 61CFF92D 61CFF92D YES
[19:59:05.692] kernel CRC32 area: addr: 00005000 len: 00001000
[19:59:05.734] FB06 00005000 00001000 38DED086 38DED086 YES
[19:59:05.734] kernel CRC32 area: addr: 00006000 len: 00001000
[19:59:05.766] FB07 00006000 00001000 F62635D4 F62635D4 YES
[19:59:05.766] kernel CRC32 area: addr: 00007000 len: 00001000
[19:59:05.798] FB08 00007000 00001000 E0A9905E E0A9905E YES
[19:59:05.798] kernel CRC32 area: addr: 00008000 len: 00018000
[19:59:06.071] FB09 00008000 00018000 163283F7 163283F7 YES
[19:59:06.071] kernel CRC32 area: addr: 00020000 len: 00020000
[19:59:06.423] FB10 00020000 00020000 F3FD4077 F3FD4077 YES
[19:59:06.423] kernel CRC32 area: addr: 00040000 len: 00020000
[19:59:06.776] FB11 00040000 00020000 FB5BA710 FB5BA710 YES
[19:59:06.776] kernel CRC32 area: addr: 00060000 len: 00020000
[19:59:07.119] FB12 00060000 00020000 2051DC75 2051DC75 YES
[19:59:07.121] kernel CRC32 area: addr: 00080000 len: 00020000
[19:59:07.476] FB13 00080000 00020000 C2FDE9A3 C2FDE9A3 YES
[19:59:07.476] kernel CRC32 area: addr: 000A0000 len: 00020000
[19:59:07.819] FB14 000A0000 00020000 2A006F9E 2A006F9E YES
[19:59:07.819] kernel CRC32 area: addr: 000C0000 len: 00020000
[19:59:08.172] FB15 000C0000 00020000 FD0D7046 4223D588 NO
[19:59:08.172] kernel CRC32 area: addr: 000E0000 len: 00020000
[19:59:08.525] FB16 000E0000 00020000 32AAD432 21833263 NO
[19:59:08.525] kernel flash disable
[19:59:08.547] kernel write flash buffer addr: 000E0000 len: 00000800
[19:59:13.677] WARNING: failure in flashing block
[19:59:13.677] kernel write flash buffer addr: 000E1000 len: 00000800
[19:59:18.797] WARNING: failure in flashing block
[19:59:18.797] kernel write flash buffer addr: 000E2000 len: 00000800
[19:59:23.926] WARNING: failure in flashing block
[19:59:23.926] kernel write flash buffer addr: 000E3000 len: 00000800
[19:59:29.056] WARNING: failure in flashing block
[19:59:29.056] kernel write flash buffer addr: 000E4000 len: 00000800
[19:59:34.185] WARNING: failure in flashing block
[19:59:34.185] kernel write flash buffer addr: 000E5000 len: 00000800
[19:59:39.314] WARNING: failure in flashing block
[19:59:39.314] kernel write flash buffer addr: 000E6000 len: 00000800
[19:59:44.434] WARNING: failure in flashing block
[19:59:44.434] kernel write flash buffer addr: 000E7000 len: 00000800
[19:59:49.562] WARNING: failure in flashing block
[19:59:49.562] kernel write flash buffer addr: 000E8000 len: 00000800
[19:59:54.690] WARNING: failure in flashing block
[19:59:54.690] kernel write flash buffer addr: 000E9000 len: 00000800
[19:59:59.818] WARNING: failure in flashing block
[19:59:59.818] kernel write flash buffer addr: 000EA000 len: 00000800
[20:00:04.945] WARNING: failure in flashing block
[20:00:04.945] kernel write flash buffer addr: 000EB000 len: 00000800
[20:00:10.076] WARNING: failure in flashing block
[20:00:10.076] kernel write flash buffer addr: 000EC000 len: 00000800
[20:00:15.205] WARNING: failure in flashing block
[20:00:15.205] kernel write flash buffer addr: 000ED000 len: 00000800
[20:00:20.334] WARNING: failure in flashing block
[20:00:20.334] kernel write flash buffer addr: 000EE000 len: 00000800
[20:00:25.465] WARNING: failure in flashing block
[20:00:25.465] kernel write flash buffer addr: 000EF000 len: 00000800
[20:00:30.594] WARNING: failure in flashing block
[20:00:30.594] kernel write flash buffer addr: 000F0000 len: 00000800
[20:00:35.722] WARNING: failure in flashing block
[20:00:35.722] kernel write flash buffer addr: 000F1000 len: 00000800
[20:00:40.851] WARNING: failure in flashing block
[20:00:40.851] kernel write flash buffer addr: 000F2000 len: 00000800
[20:00:45.981] WARNING: failure in flashing block
[20:00:45.981] kernel write flash buffer addr: 000F3000 len: 00000800
[20:00:51.113] WARNING: failure in flashing block
[20:00:51.113] kernel write flash buffer addr: 000F4000 len: 00000800
[20:00:56.241] WARNING: failure in flashing block
[20:00:56.241] kernel write flash buffer addr: 000F5000 len: 00000800
[20:01:01.370] WARNING: failure in flashing block
[20:01:01.370] kernel write flash buffer addr: 000F6000 len: 00000800
[20:01:06.498] WARNING: failure in flashing block
[20:01:06.498] kernel write flash buffer addr: 000F7000 len: 00000800
[20:01:11.632] WARNING: failure in flashing block
[20:01:11.632] kernel write flash buffer addr: 000F8000 len: 00000800
[20:01:16.760] WARNING: failure in flashing block
[20:01:16.760] kernel write flash buffer addr: 000F9000 len: 00000800
[20:01:21.889] WARNING: failure in flashing block
[20:01:21.889] kernel write flash buffer addr: 000FA000 len: 00000800
[20:01:27.019] WARNING: failure in flashing block
[20:01:27.019] kernel write flash buffer addr: 000FB000 len: 00000800
[20:01:32.148] WARNING: failure in flashing block
[20:01:32.148] kernel write flash buffer addr: 000FC000 len: 00000800
[20:01:37.280] WARNING: failure in flashing block
[20:01:37.280] kernel write flash buffer addr: 000FD000 len: 00000800
[20:01:42.408] WARNING: failure in flashing block
[20:01:42.408] kernel write flash buffer addr: 000FE000 len: 00000800
[20:01:47.536] WARNING: failure in flashing block
[20:01:47.536] kernel write flash buffer addr: 000FF000 len: 00000800
[20:01:52.666] WARNING: failure in flashing block
[20:01:52.666] kernel write flash buffer addr: 000C0000 len: 00000800
[20:01:57.806] WARNING: failure in flashing block
[20:01:57.806] kernel write flash buffer addr: 000C1000 len: 00000800
[20:02:02.934] WARNING: failure in flashing block
[20:02:02.934] kernel write flash buffer addr: 000C2000 len: 00000800
[20:02:08.062] WARNING: failure in flashing block
[20:02:08.062] kernel write flash buffer addr: 000C3000 len: 00000800
[20:02:13.191] WARNING: failure in flashing block
[20:02:13.191] kernel write flash buffer addr: 000C4000 len: 00000800
[20:02:18.315] WARNING: failure in flashing block
[20:02:18.315] kernel write flash buffer addr: 000C5000 len: 00000800
[20:02:23.440] WARNING: failure in flashing block
[20:02:23.440] kernel write flash buffer addr: 000C6000 len: 00000800
[20:02:28.566] WARNING: failure in flashing block
[20:02:28.566] kernel write flash buffer addr: 000C7000 len: 00000800
[20:02:33.693] WARNING: failure in flashing block
[20:02:33.693] kernel write flash buffer addr: 000C8000 len: 00000800
[20:02:38.818] WARNING: failure in flashing block
[20:02:38.818] kernel write flash buffer addr: 000C9000 len: 00000800
[20:02:43.946] WARNING: failure in flashing block
[20:02:43.946] kernel write flash buffer addr: 000CA000 len: 00000800
[20:02:49.072] WARNING: failure in flashing block
[20:02:49.072] kernel write flash buffer addr: 000CB000 len: 00000800
[20:02:54.195] WARNING: failure in flashing block
[20:02:54.195] kernel write flash buffer addr: 000CC000 len: 00000800
[20:02:59.323] WARNING: failure in flashing block
[20:02:59.323] kernel write flash buffer addr: 000CD000 len: 00000800
[20:03:04.449] WARNING: failure in flashing block
[20:03:04.449] kernel write flash buffer addr: 000CE000 len: 00000800
[20:03:09.578] WARNING: failure in flashing block
[20:03:09.578] kernel write flash buffer addr: 000CF000 len: 00000800
[20:03:14.704] WARNING: failure in flashing block
[20:03:14.704] kernel write flash buffer addr: 000D0000 len: 00000800
[20:03:19.829] WARNING: failure in flashing block
[20:03:19.829] kernel write flash buffer addr: 000D1000 len: 00000800
[20:03:24.960] WARNING: failure in flashing block
[20:03:24.960] kernel write flash buffer addr: 000D2000 len: 00000800
[20:03:30.089] WARNING: failure in flashing block
[20:03:30.089] kernel write flash buffer addr: 000D3000 len: 00000800
[20:03:35.206] WARNING: failure in flashing block
[20:03:35.206] kernel write flash buffer addr: 000D4000 len: 00000800
[20:03:40.337] WARNING: failure in flashing block
[20:03:40.337] kernel write flash buffer addr: 000D5000 len: 00000800
[20:03:45.467] WARNING: failure in flashing block
[20:03:45.467] kernel write flash buffer addr: 000D6000 len: 00000800
[20:03:50.594] WARNING: failure in flashing block
[20:03:50.594] kernel write flash buffer addr: 000D7000 len: 00000800
[20:03:55.724] WARNING: failure in flashing block
[20:03:55.724] kernel write flash buffer addr: 000D8000 len: 00000800
[20:04:00.854] WARNING: failure in flashing block
[20:04:00.854] kernel write flash buffer addr: 000D9000 len: 00000800
[20:04:05.982] WARNING: failure in flashing block
[20:04:05.982] kernel write flash buffer addr: 000DA000 len: 00000800
[20:04:11.111] WARNING: failure in flashing block
[20:04:11.111] kernel write flash buffer addr: 000DB000 len: 00000800
[20:04:16.242] WARNING: failure in flashing block
[20:04:16.242] kernel write flash buffer addr: 000DC000 len: 00000800
[20:04:21.436] WARNING: failure in flashing block
[20:04:21.440] kernel write flash buffer addr: 000DD000 len: 00000800
[20:04:26.598] WARNING: failure in flashing block
[20:04:26.598] kernel write flash buffer addr: 000DE000 len: 00000800
[20:04:31.728] WARNING: failure in flashing block
[20:04:31.728] kernel write flash buffer addr: 000DF000 len: 00000800
[20:04:36.859] WARNING: failure in flashing block
[20:04:36.859] kernel flash disable
[20:04:36.880] verifying result...
[20:04:36.880] comparing ECU flash memory pages to image file
[20:04:36.880] seg start len ecu CRC32 img CRC32 same?
[20:04:36.880] kernel CRC32 area: addr: 00000000 len: 00001000
[20:04:36.911] FB01 00000000 00001000 AE6D8A07 AE6D8A07 YES
[20:04:36.911] kernel CRC32 area: addr: 00001000 len: 00001000
[20:04:36.942] FB02 00001000 00001000 EA035F4B EA035F4B YES
[20:04:36.942] kernel CRC32 area: addr: 00002000 len: 00001000
[20:04:36.974] FB03 00002000 00001000 21A08FCB 21A08FCB YES
[20:04:36.974] kernel CRC32 area: addr: 00003000 len: 00001000
[20:04:37.016] FB04 00003000 00001000 EB2F3706 EB2F3706 YES
[20:04:37.016] kernel CRC32 area: addr: 00004000 len: 00001000
[20:04:37.057] FB05 00004000 00001000 61CFF92D 61CFF92D YES
[20:04:37.057] kernel CRC32 area: addr: 00005000 len: 00001000
[20:04:37.088] FB06 00005000 00001000 38DED086 38DED086 YES
[20:04:37.088] kernel CRC32 area: addr: 00006000 len: 00001000
[20:04:37.119] FB07 00006000 00001000 F62635D4 F62635D4 YES
[20:04:37.119] kernel CRC32 area: addr: 00007000 len: 00001000
[20:04:37.151] FB08 00007000 00001000 E0A9905E E0A9905E YES
[20:04:37.151] kernel CRC32 area: addr: 00008000 len: 00018000
[20:04:37.413] FB09 00008000 00018000 163283F7 163283F7 YES
[20:04:37.413] kernel CRC32 area: addr: 00020000 len: 00020000
[20:04:37.765] FB10 00020000 00020000 F3FD4077 F3FD4077 YES
[20:04:37.765] kernel CRC32 area: addr: 00040000 len: 00020000
[20:04:38.118] FB11 00040000 00020000 FB5BA710 FB5BA710 YES
[20:04:38.118] kernel CRC32 area: addr: 00060000 len: 00020000
[20:04:38.461] FB12 00060000 00020000 2051DC75 2051DC75 YES
[20:04:38.461] kernel CRC32 area: addr: 00080000 len: 00020000
[20:04:38.814] FB13 00080000 00020000 C2FDE9A3 C2FDE9A3 YES
[20:04:38.814] kernel CRC32 area: addr: 000A0000 len: 00020000
[20:04:39.167] FB14 000A0000 00020000 2A006F9E 2A006F9E YES
[20:04:39.167] kernel CRC32 area: addr: 000C0000 len: 00020000
[20:04:39.520] FB15 000C0000 00020000 FD0D7046 4223D588 NO
[20:04:39.520] kernel CRC32 area: addr: 000E0000 len: 00020000
[20:04:39.863] FB16 000E0000 00020000 32AAD432 21833263 NO
[20:04:39.884] interface close
[20:04:39.936] interface close
mgv101
Postby legaulois » Sun Oct 05, 2008 9:24 pm
I have the same problem.
I informed cboles, one week ago. him there job :wink:
C Boles 30/09/2008 wrote:My only guess at this point is that your ECU circuit board is wired a little differently that the ones in the US market and that maybe the flash is not being enabled for writing. The "kernel flash enable" command is supposed to check the FWE bit though, so I am still a little confused. Is it possible that you can take a photograph of the front and back of the ECU circuit board for me? I would like to check to see if this ECU is the same as the USDM ones. I will be out of the office until 2008/10/5 - I will check back then.
I gave him photos high definition
for all infos : http://www.tactrix.com/bugs/view.php?id=2
legaulois
Postby mdonohoe » Sun Oct 05, 2008 11:03 pm
Hmm. I tried a test write on a Australian Domestic MY08 WRX(non-sti)... It all seemed AOK? Lookie...
[16:57:47.953] Version 1.38.2080
[16:57:47.953] 11 memory models read.
[16:57:47.953] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[16:57:53.828] 320 ROM metadata models scanned.
[16:57:53.828] checksum module "subarudbw" loaded.
[16:57:53.828] flashing tool "wrx02" loaded.
[16:57:53.828] flashing tool "wrx04" loaded.
[16:57:53.828] flashing tool "sti04" loaded.
[16:57:53.828] flashing tool "sti05" loaded.
[16:57:53.828] flashing tool "mitsukernel" loaded.
[16:57:53.828] flashing tool "mitsukernelocp" loaded.
[16:57:53.828] flashing tool "shbootmode" loaded.
[16:57:53.906] flashing tool "shaudmode" loaded.
[16:57:53.906] flashing tool "subarucan" loaded.
[16:58:07.375] AZ1E400C (255 tables) inheriting 32BITBASE (662 tables)
[16:58:07.781] 1048576 byte image read.
[16:59:31.562] kernel get version
[16:59:31.968] SSM2 init
[16:59:32.046] SSM2 ECU ID is 51 52 58 40 07
[16:59:32.078] Requesting Seed...
[16:59:32.140] Sending Key...
[16:59:34.734] kernel get version
[16:59:34.781] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.05
[16:59:34.781] reading kernel comm buffer size
[16:59:34.843] comm buffer size set to 2048
[16:59:34.859] reading kernel flash buffer size
[16:59:34.906] flash buffer size set to 4096
[16:59:34.921] Test flashing image to ECU memory...
[16:59:35.328] comparing ECU flash memory pages to image file
[16:59:35.328] seg start len ecu CRC32 img CRC32 same?
[16:59:35.328] kernel CRC32 area: addr: 00000000 len: 00001000
[16:59:35.375] FB01 00000000 00001000 3019EEFC 3019EEFC YES
[16:59:35.390] kernel CRC32 area: addr: 00001000 len: 00001000
[16:59:35.437] FB02 00001000 00001000 750D1713 750D1713 YES
[16:59:35.453] kernel CRC32 area: addr: 00002000 len: 00001000
[16:59:35.515] FB03 00002000 00001000 804C543D 804C543D YES
[16:59:35.515] kernel CRC32 area: addr: 00003000 len: 00001000
[16:59:35.546] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[16:59:35.546] kernel CRC32 area: addr: 00004000 len: 00001000
[16:59:35.578] FB05 00004000 00001000 53A157C9 53A157C9 YES
[16:59:35.578] kernel CRC32 area: addr: 00005000 len: 00001000
[16:59:35.609] FB06 00005000 00001000 0644E9D6 0644E9D6 YES
[16:59:35.609] kernel CRC32 area: addr: 00006000 len: 00001000
[16:59:35.656] FB07 00006000 00001000 AA4FE5DD AA4FE5DD YES
[16:59:35.656] kernel CRC32 area: addr: 00007000 len: 00001000
[16:59:35.703] FB08 00007000 00001000 259EEE33 259EEE33 YES
[16:59:35.703] kernel CRC32 area: addr: 00008000 len: 00018000
[16:59:35.875] FB09 00008000 00018000 6036A298 6036A298 YES
[16:59:35.890] kernel CRC32 area: addr: 00020000 len: 00020000
[16:59:36.093] FB10 00020000 00020000 8D11C606 8D11C606 YES
[16:59:36.109] kernel CRC32 area: addr: 00040000 len: 00020000
[16:59:36.328] FB11 00040000 00020000 5FF1A74A 5FF1A74A YES
[16:59:36.343] kernel CRC32 area: addr: 00060000 len: 00020000
[16:59:36.562] FB12 00060000 00020000 5F6E70B5 5F6E70B5 YES
[16:59:36.578] kernel CRC32 area: addr: 00080000 len: 00020000
[16:59:36.796] FB13 00080000 00020000 018F14E4 018F14E4 YES
[16:59:36.812] kernel CRC32 area: addr: 000A0000 len: 00020000
[16:59:37.031] FB14 000A0000 00020000 DF1BA44A DF1BA44A YES
[16:59:37.046] kernel CRC32 area: addr: 000C0000 len: 00020000
[16:59:37.265] FB15 000C0000 00020000 D5F196D1 D5F196D1 YES
[16:59:37.281] kernel CRC32 area: addr: 000E0000 len: 00020000
[16:59:37.484] FB16 000E0000 00020000 951764ED 951764ED YES
[16:59:37.500] flash image is identical! exiting.
[16:59:37.562] interface close
[16:59:37.656] interface close
Comments?!??!
mdonohoe
Postby legaulois » Sun Oct 05, 2008 11:07 pm
they think that it is EDM with this probléme
legaulois
Postby mdonohoe » Mon Oct 06, 2008 12:06 am
Hmm. Interesting. Guess living in Australia finally pays off???
mdonohoe
