2002 JDM WRX
Hi guys,
I've had my WRX for about 2 months now and finally got a laptop borrowed to mess around with the OpenPort 1.2 cable and ecuExplorer.
So for I have done some datalogging, tried the adjust timing and adjust idle functions and all is well. The ECU is AF471-7086. I've found the IAM at 020118. My own only is only reading 10 though.
I can't seem to get the Read ECU Flash Memory function to work though. Under the dash has the 2 green connectors, 2 black connectors and one 2 wire white connector. I connected the 2 green ones together and shorted the 2 wires on the white connector but that is not working. Can anyone confirm if this function works on 02 JDM ECU's? And if so, am I following the right procedures?
Thanks,
Michael
Thanks,
Michael
