USDM 2007 WRX STI LIMITED EDITON 2.5 TURBO (FACTORY REMAP)
Postby zefex » Sat Jun 02, 2007 12:07 am
Hi everhyone, this is my first post, im not sure what im doing here on the forums but i wanted to post my hex file for my 07 WRX STI Limited with Factory Hesitation Remap. I hope this can be of some use.
Edit: Corrected Map Version to just Remap, Sorry for the misstatement.
07_sti_limited_image.hex
USDM 2007 WRX STI LIMITED EDITON 2.5 TURBO (FACTORY REMAP 2)
(1 MiB) Downloaded 1279 times
zefex
Postby Jon [in CT] » Sat Jun 02, 2007 7:49 am
SOA has issued only one fix (remap), so far, for the US 2007 STI - A2UJ000J. The ROM attached above is that fix.
Postby STIBungy » Fri Jan 11, 2008 2:07 pm
Wow, the fuel maps for the 07 STI drops all the way down to 9.5. Is that because the 07 is more prone to detonation?
STIBungy
Re: USDM 2007 WRX STI LIMITED EDITON 2.5 TURBO (FACTORY REMA
Postby Alex Maroto » Mon Sep 16, 2013 7:46 pm
Hi
Could you please provide details of how to pull the map down the ECU, I haven´t been able to do it form two 2007 STI
I have had trouble with two Canada/USA Limited STI 2.5 2007, sold in my country.
I tried two computers (Lenovo and Hitachi), two Open port 2.0, two operating systems XP and Win7), two ecuflash versions: 1.42.2595 and 1.44.3721 without success
I used to flash many cars from 2001 to 2013 with no problems at all, but I haven´t been able to flash those 2007 STI´s
The log data says: Interface closed: GRRRRR!!!!
I check the green connectors, the car does the self check routine (so they start the check procedure) but I haven´t been able to pull the OEM map
Any ideas?
[09:22:10.888] EcuFlash Version 1.44.3721
[09:22:10.888] OS Version Windows 7
[09:22:10.888] Qt Version 4.8.0
[09:22:10.903] 63 memory models read.
[09:22:10.903] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata
[09:22:11.013] 354 ROM metadata models scanned.
[09:22:11.013] checksum module "subarudbw" loaded.
[09:22:11.013] checksum module "mitsucan" loaded.
[09:22:11.013] checksum module "mitsuh8" loaded.
[09:22:11.013] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[09:22:11.013] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[09:22:11.013] flashing tool "wrx02" loaded.
[09:22:11.013] flashing tool "wrx04" loaded.
[09:22:11.013] flashing tool "sti04" loaded.
[09:22:11.013] flashing tool "sti05" loaded.
[09:22:11.013] flashing tool "mitsukernel" loaded.
[09:22:11.013] flashing tool "mitsukernelocp" loaded.
[09:22:11.013] flashing tool "mitsubootloader" loaded.
[09:22:11.013] flashing tool "shbootmode" loaded.
[09:22:11.013] flashing tool "shaudmode" loaded.
[09:22:11.013] flashing tool "subarucan" loaded.
[09:22:11.028] flashing tool "subarucand" loaded.
[09:22:11.028] flashing tool "mitsucan" loaded.
[09:22:11.091] J2534 API Version: 04.04
[09:22:11.091] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:22:11.091] Device Firmware Version: 1.12.3688
[09:22:11.091] Device Serial Number: TAf3sr9J
[09:22:11.091] interface close
[09:22:11.122] J2534 API Version: 04.04
[09:22:11.122] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:22:11.122] Device Firmware Version: 1.12.3688
[09:22:11.122] Device Serial Number: TAf3sr9J
[09:22:11.122] interface close
[09:22:11.153] J2534 API Version: 04.04
[09:22:11.153] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:22:11.153] Device Firmware Version: 1.12.3688
[09:22:11.153] Device Serial Number: TAf3sr9J
[09:22:11.153] interface close
[09:23:38.076] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_sti05.xml
[09:23:38.092] J2534 API Version: 04.04
[09:23:38.092] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:23:38.092] Device Firmware Version: 1.12.3688
[09:23:38.092] Device Serial Number: TAf3sr9J
[09:23:43.156] This action is unsupported for this ECU.
[09:23:43.156] interface close
[09:23:49.640] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_sti05.xml
[09:23:49.655] J2534 API Version: 04.04
[09:23:49.655] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:23:49.655] Device Firmware Version: 1.12.3688
[09:23:49.655] Device Serial Number: TAf3sr9J
[09:23:50.672] This action is unsupported for this ECU.
[09:23:50.672] interface close
[09:24:00.380] using metadata XML ID read_sti05 from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_sti05.xml
[09:24:00.395] J2534 API Version: 04.04
[09:24:00.395] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:24:00.395] Device Firmware Version: 1.12.3688
[09:24:00.395] Device Serial Number: TAf3sr9J
[09:24:02.136] This action is unsupported for this ECU.
[09:24:02.136] interface close
[09:24:07.787] using metadata XML ID read_subarush7058can from file C:/Program Files (x86)/OpenECU/EcuFlash1422595/rommetadata/read templates/read_subarush7058can.xml
[09:24:07.818] J2534 API Version: 04.04
[09:24:07.818] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[09:24:07.818] Device Firmware Version: 1.12.3688
[09:24:07.818] Device Serial Number: TAf3sr9J
[09:24:09.169] This action is unsupported for this ECU.
[09:24:09.169] interface close
Alex Maroto
Postby 3sgte » Tue Oct 08, 2013 7:49 pm
ecu is maybe locked by Accessport or EcuTek
3sgte
Postby jaxscuby » Sat Oct 26, 2013 3:12 pm
you should not be trying to down load as 2005 STi...did you see that?
you said it was an 2007, so it would be 2006
jaxscuby
Postby Alex Maroto » Fri Nov 01, 2013 8:26 pm
jaxscuby wrote:you should not be trying to down load as 2005 STi...did you see that?
Thanks, I did that on purpose becuase I wanted to try several protocols to test different ECUs, but never help..
The car was sold localy and its very difficult to have Ecutek or Cobb here, I am a Ecutek dealer and the car is not licensed, so there must be something else
Alex Maroto
Postby nick_f » Wed Nov 20, 2013 4:06 am
try to read cpu with piasini if you have and reflash original file and read again with openport.
nick_f
