A8DH200O ADM 2006 WRX
Postby prana » Mon Mar 26, 2007 4:12 pm
Here's a new rom image with no definitions in EcuFlash. Offset of image stamp is at 0x2000
ADM 06 WRX DBW_A8DH200O.hex
(1 MiB) Downloaded 896 times
prana
Postby msgofast » Mon Mar 26, 2007 5:03 pm
msgofast
Postby merchgod » Mon Mar 26, 2007 5:44 pm
Enginuity has coverage for that rom.
merchgod
Postby prana » Mon Mar 26, 2007 6:04 pm
awesome. I suspect XMLWrite should have a def then. Might be able to create one. I'll look to see
Got it, cheers merchgod.
prana
Postby larrikinstreak » Tue Mar 27, 2007 5:13 pm
prana wrote:awesome. I suspect XMLWrite should have a def then. Might be able to create one. I'll look to see
I have been download'n with ecuflash, edit with enginuity, is there another way now ?
larrikinstreak
Postby prana » Thu Mar 29, 2007 1:40 am
yea, you create an xml def using xmlwrite and put it into the metadata folder, provided xmlwrite has it defined. Remember I was saying the offsets are all stored in the xml files ? This is a mighty fine ROM, lots of features.
prana
Postby larrikinstreak » Thu Mar 29, 2007 4:33 pm
prana wrote:yea, you create an xml def using xmlwrite and put it into the metadata folder, provided xmlwrite has it defined. Remember I was saying the offsets are all stored in the xml files ? This is a mighty fine ROM, lots of features.
Ok, will try that , thanks Steve.
larrikinstreak
Postby msgofast » Sun Nov 25, 2007 8:41 pm
Can you explan to me how that is done?
msgofast
Postby larrikinstreak » Tue Nov 27, 2007 7:03 pm
msgofast wrote:Can you explan to me how that is done?
Michael you'll find it easier to get the defs for any recent rom from those that come with Enginuity, if the site is up ? I did this with a my06 rom when they first apperared.
Geoff.
larrikinstreak
Postby msgofast » Tue Nov 27, 2007 7:10 pm
I down loaded 1.34 and all fixed.
thanks.
msgofast
Postby kroogz » Mon Apr 21, 2008 11:20 pm
Is this a stock base map for 06 WRX or is it a tweaked map?
kroogz
