by Freon » Fri Mar 02, 2007 12:58 pm
You can look through Ecuflash's directory structure (c:\program files\openecu\ecuflash) to see in general where the XML files are.
The three major available editors all use different formats of XML (Ecuflash, Ecuedit, and Enguinity). There are no tools to convert XML from either of the other two to Ecuflash. You'd have to do it by hand.
You're probably better off just downloading Enguinity and using that.
