Boost Oscillation
Boost Oscillation
Postby criscross79 » Tue Jan 09, 2007 12:23 pm
Well, I just reflashed to Stage 2 with the free stage 2 map by ev8siv3 and I am getting some pretty big boost oscillations. I did have a MBC on the car, but I took that off before I went to stage 2. Any idea what might be the problem?
Here are a few logs that I just did.
BTW this is a '02 4EAT. I didn't run any of the logs in any particular gear just 3rd and Drive.
For reference my mods are: helix style uppipe, stromung shorty dp w/ stock 3rd cat, Megan Racing 3" cat back exhaust, silencer air box removed.
Thanks for any input
Chris
ecuExplorer [AF426] 09-01-2007 11h31m26s.xls
1-120 mph 2/3s throttle
(97 KiB) Downloaded 262 times
ecuExplorer [AF426] 09-01-2007 11h30m17s.xls
70-120 mph Full Throttle
(87.5 KiB) Downloaded 268 times
ecuExplorer [AF426] 09-01-2007 11h32m47s.xls
45 to 85 mph, 1/3 throttle
(86.5 KiB) Downloaded 265 times
criscross79
Postby Freon » Tue Jan 09, 2007 4:00 pm
It looks like the proportional and integral turbo dynamics maps are WAY too hot.
I'd cut down the values a lot in those maps, especially near the center. You're jumping up and down on wastegate duty by 20% and boost by about 2.5 psi. This is purely due to a bad setup on the turbo dynamics maps.
Go back to something that looks more like the stock turbo dynamics maps. You can maybe average the values from your map and the stock map, or go all the way back to the stock setu.
Users browsing this forum: No registered users and 65 guests
