Jon [in CT] wrote:zigzagzok, can you recall which option you selected when you reached the screen shown below?
i believe i selected the "no not this time" and manually pointed the installation to the folder where i unzipped the files
Jon [in CT] wrote:That was the correct action. I was just trying to explore possible reasons why EcuFlash can't do a successful SSM protocol Init command, whereas EcuExplorer succeeds.
Spadman wrote:I know this may be an obvious point.... have you plugged together BOTH green plugs?
There is one on the passenger side near the ECU, which you have a picture of, but there is also one under the outside kick plate on the drivers side floor e.g. under the plastic cover near your accelerator pedal.
Also, I have never found any difference in timing the turning on of the ignition and pressing the OK button to read the ROM. I just turn the car to on, and then press OK whenever I get around to it.
The ODO shows Er HC and the ROM reads (I had to use the STI 04 setting in ecuflash).
Hope some of this helps.
Jon [in CT] wrote:How many times have you tried to read the ROM from other Subarus (not yours) and were you ever successful?
