Boost Cut
Boost Cut
Postby Rallitek.com » Wed Sep 27, 2006 11:43 am
Anyone having trouble with boost cut? I have a car that runs 1.2bar but is still getting boost cut (PO244) even though the boost cut is set to 21.9(1.5bar).
Thanks!
Rallitek.com
Postby crispyduck » Wed Sep 27, 2006 12:11 pm
What car?
Also post your ROM so we can take a look.
Postby absubtle » Wed May 23, 2007 6:48 pm
On the Boost Cut page, there is Atmosphere relative pressure and then there is Boost PSI relative.
The Atmosphere is for your altitude. Sea level is 14.7.
Up here in Denver it's 12.0.
You have to adjust the boost cut for your atmosphere relative pressure. I just change the value for the Boost PSI relative across the board.
Hope this helps.
Absubtle
CO
absubtle
Postby oscarmayer » Thu Dec 27, 2007 6:18 pm
oscarmayer
Postby korhan » Fri Dec 05, 2008 6:01 pm
maybe you write the boost cut(fuel) high but for the cel, you also have to write boost limit(cel) higher.
korhan
