Post a graph.
I think setting it in 2 or 3gear and floor it from 0kph
It might ping
My non-turbo is low due to the 4EAT
2.00, 240 & 2.80 are low compare to others (2k-4k range)
I know you lean out things a bit to get the turbo spooling, but in my case, that is not the case and I do not think that is the same for the turbo models. I feel it is emissions, since that is the point when you accelerates or move of in traffic and around town.
If my opinion is correct, I feel that this area can be improve.
Our ignition map in that area looks good, but the fuel and avcs is questionable.
This is what to do, sine the map is base on load. The problem is speed.
Choose either 2/3 gear and do some dyno runs as you increase the avcs in those regions.
Lets take increases by 2degrees to cut down the number of runs.
I am sorry that you are not in the Caribbean
![Smile :)](./images/smilies/icon_smile.gif)
I feel like doing something now.
