reflashed MY05 USDM LGT with map I made
Postby 05GarnetLGT » Sun Jun 04, 2006 8:18 pm
flash worked, started right up, but it threw a code P0605, Internal Control Module Read Only Memory error?
wtf?
so I flashed back to stock and and the cel was gone.
Uploading my modded map to see if anyone knows what was wrong.
I raised the rev limiter to 6900/6800, boost up, wg max dc up.
A2WC510Cmodded.hex
my modded map, threw a cel
(1 MiB) Downloaded 751 times
05GarnetLGT
Postby JRSCCivic98 » Mon Jun 05, 2006 4:45 am
Possible checksum issues?
Postby Evo4Mad » Mon Jun 05, 2006 5:09 am
Did you set the new checksums?
Postby 05GarnetLGT » Mon Jun 05, 2006 5:47 am
no, thought ecuedit handled that automatically?
05GarnetLGT
Postby 05GarnetLGT » Thu Jun 08, 2006 3:28 pm
so uhh, how do i set checksums then?
05GarnetLGT
Postby Jon [in CT] » Fri Jun 09, 2006 7:07 am
http://www.openecu.org/index.php?title= ... _Algorithm
But, according to the revision history for EcuFlash at http://www.openecu.org/index.php?title=EcuFlash, version 1.26 has a checksum module for DBW Subarus.
Postby 05GarnetLGT » Fri Jun 09, 2006 8:26 am
so I have to manually go in with a hex editor and turn off checksumming my ECU? doesnt sound like that great of an idea to me...
05GarnetLGT
Postby NeverLies » Fri Jun 09, 2006 10:32 am
Epifan told also that EcuEdit handles checksum. Just need to get the latest release and it should work.
When you create XML file using XMLWrite, Checksum block is visible. You may compare the original checksum block with the one generated by save operation by Ecuedit.
You may also use EcuFlash that for sure manage checksum correctly. Tested and approved ! :D
Postby ev8siv3 » Mon Jun 12, 2006 1:17 pm
I've created a simple HOW TO on my website to show how to fix the Checksum on all DBW ecu's via HEX.
http://www.osecuroms.org/viewtopic.php?t=58
ev8siv3
Postby 05GarnetLGT » Tue Jun 13, 2006 6:30 am
ahhh, finally, a plain english explanation of what to input, exactly.
*off to dl tinyhexer*
05GarnetLGT
Users browsing this forum: No registered users and 38 guests
