Connect Trouble 06WRX (interface close)?
Postby Watt Master » Wed Aug 18, 2010 7:15 pm
Just got my OP2 and tried to read the ECU , the process fails and says see log.
I scroll down the log(about 30sec. of log) and I get...
[18:39:56.623] kernel get version
[18:39:56.998] SSM2 init
[18:39:57.138] SSM2 ECU ID is 43 12 58 41 06
[18:39:57.232] Requesting Seed...
[18:39:57.278] Sending Key...
[18:39:57.902] interface close
[18:39:57.934] interface close
This was my first time to use ECU and OP2 and tried several times with no luck.
Once I tried with the car running and it died but restarted fine. Just to see if I could connect I ran Learning View and it read all parameters so I know I can talk.
This car has been tuned with RR and ECU Falsh at a shop, could the tuner have locked my ECU?
I do not want to tune or flash right now I just want to log but to log I belive you have to have a copy of your current tune on the computer your logging with.
Watt Master
Re: Connect Trouble 06WRX (interface close)?
Postby Watt Master » Wed Aug 18, 2010 9:18 pm
OK, it was the green connector.
I'm sure I have read in a couple places that the 2005 and older had the connector.
Thanks to all for looking.
Watt Master
Users browsing this forum: No registered users and 37 guests
