Turning off DTCs: Evo 8
Postby Dirty25rs » Mon Apr 05, 2010 5:45 am
How can I/Can I permanently turn off DTCs on a USDM Evo 8 like you can on subarus?
If so, what software?
If ECUflash, how?
Sorry for the noob question.
Dirty25rs
Re: Turning off DTCs: Evo 8
Postby todd-w » Mon Apr 05, 2010 11:32 am
what do you want switched off , ecu periphery bits can switch most of em off
todd-w
Postby Dirty25rs » Mon Apr 05, 2010 12:02 pm
Cant remember the number exactly. something like P0420
My Innovate says its "Catalytic Converter Efficiency below threshold"
Dirty25rs
Postby todd-w » Mon Apr 05, 2010 1:20 pm
try in ecu periphery faa bits set bit 1 to 0
todd-w
Postby Dirty25rs » Mon Apr 05, 2010 5:49 pm
I need to know more about what exactly i'm doing by changing that bit before I do it.
you understand....
Dirty25rs
Postby todd-w » Tue Apr 06, 2010 12:42 pm
do you still have the catalytic converter and rear o2 sensor ???? im presuming you have removed the cat and now the rear o2 thinks you cat is goosed . the above switches off the rear o2 sensor but if you need obd readiness for emissions testing there another method
todd-w
Postby Dirty25rs » Tue Apr 06, 2010 3:03 pm
I actually still have the rear O2, I have a high flow cat. cars running on E85.
I have found the availability and pass/fail modification procedure on evolutionm.net
but my car still will throw a P0420 code on the way to the emissions place even with those bits changed, i presume.
Dirty25rs
Postby todd-w » Wed Apr 07, 2010 12:11 pm
wont hurt to check them
todd-w
Postby todd-w » Thu Apr 08, 2010 12:06 pm
try bit 1 in Fca bits also change from 1 to 0
todd-w
Users browsing this forum: Bing [Bot] and 31 guests
