Colt czt definitions
Postby Marmes » Sun Feb 22, 2009 11:28 am
Does anyone has the xml file for a colt czt?
stock-XMCMNZ37A6F012413.bin
(512 KiB) Downloaded 1095 times
Marmes
Re: Colt czt definitions
Postby acamus » Thu Feb 26, 2009 1:41 am
ROMID = 47110032
ECU Family = JM4711
SCC = E234
I will see what can be done
acamus
Postby Marmes » Thu Feb 26, 2009 5:26 pm
Thank you very much :D
Marmes
Postby peps_sti » Fri Feb 27, 2009 3:30 pm
How have you downloaded it?
peps_sti
Postby christian_piasini » Mon Mar 02, 2009 3:18 pm
PEP-STI, Marmes is in the same boat as you... ;-)
the file was my gift same to you for the 2.4L Outlander.
Postby Marmes » Mon Mar 02, 2009 4:07 pm
Yes,
The file was a kind gift from Christian, that tuned my car and made a very happy guy :)
This is the original file read by Piasini Tool, wich I strongly advise to give a check!
Cheers!
Marmes
Postby coltcztowner » Sat Mar 14, 2009 6:46 pm
acamus wrote:ROMID = 47110032
ECU Family = JM4711
SCC = E234
Any news?
Not sure if the maps below are correct:
3 timing maps:
High octane timing 1 - 535DD
low octane timing 1 - 536F5
High octane timing 2 - 538D5
low octane timing 2 - 539ED
High octane timing 3 - 53BCD
low octane timing 3 - 53CE5
fuel maps:
High octane fuel - 53EC5
low octane fuel - 53FAD
coltcztowner
Postby coltcztowner » Mon Mar 16, 2009 3:08 pm
Timing maps are 16x17
rpm axis - 4EBFE
load axis - 4EC24
fuel maps are 14x16
rpm axis - 4EBB6
load axis - 4EBD8
coltcztowner
Postby acamus » Mon Mar 16, 2009 10:32 pm
I have done only fuel, the values above seem correct. I have not had enough time for timing
Warmup Map seems to be RPM 4F402(16), Load 4F42A(15), AFR 54997
Open Loop Load seems to be RPM 4EB80(14), Load 54406
acamus
Postby coltcztowner » Tue Mar 17, 2009 1:20 am
Waiting with patience... Thanks for your time.
If i find anything else, I'll post here. A lot of maps inside ROM!
Anybody knows the revlimit?
It would be great if we had an xml with basic stuff at the begining... And update it later on with new maps found.
coltcztowner
Postby coltcztowner » Tue Mar 17, 2009 3:08 pm
I think mivec intake advance lays here: 5446F (16x15)
But i can not locate rpm and load axis.
coltcztowner
Postby acamus » Wed Mar 18, 2009 5:34 am
axis for this map are at 4F024, 4F000
acamus
Postby Marmes » Wed Mar 18, 2009 2:16 pm
I am after the checksum of this.
Marmes
Postby coltcztowner » Wed Mar 25, 2009 3:17 am
Another ignition map - 54665 (16x17)... looks like a warmup ignition map...?
Just after each couple of high and low octane ignition maps, there is another map which seems like an ignition trim for each couple.
5380D (16x12)
53B05 (16x12)
53DFD (16x12)
All three are exactly the same. Maybe EGR enabled ignition trims?
coltcztowner
Postby coltcztowner » Wed Apr 01, 2009 3:01 pm
5380D (16x12)
53B05 (16x12)
53DFD (16x12)
for these maps: rpm axis 4EBFE, load axis 4ECEC.
coltcztowner
