WEIRD BEHAVIOR
WEIRD BEHAVIOR
Postby TALONTRAX » Tue Mar 13, 2007 5:46 pm
I have a 98 Tsi awd. 5 speed. The car has a list of mods 16G, safc, supporting mods. The car has always run perfect. I only drive it for fun, it`s not a d.d. Heres what it`s doing out of the blue:
Starts, & idles rough (always had a perfect smooth idle)
Has hesitations/dead spots in the throttle (just off idle)
Anywhere past 30% throttle, & onset of boost, it will pop loudly, misfire, lose power, & a/f. guage reads 1.01v!!
sounds like something is causing super rich condition, boost leak ????
What I`ve checked so far:
Boost leaks,rigged up a pvc.pipe with a quick-release air fitting, & charged entire system(upper, lower ic.pipes,intercooler, bov. valve, but not the compressor) with 25 psi, no leaks.
Tried another maf, (stock 2G)no change
Tested the tps. with a dvom,nice smooth sweep, full range present
Tested the map.sensor, voltage is 1.65 at idle, & rises close to 5v as it gets closer to 0 vac. or boost(accelerating).
Any ideas ??? This car ran absolutely perfect until the other day, then these symptoms came up out of the blue.
Maf. reset output transistor ??? What is it`s function? Could this be my problem? Where is it located, inside the maf, or the ecu?
TALONTRAX
Users browsing this forum: No registered users and 14 guests
